Injector scaling and latecy for different injectors.
#31
Originally Posted by MalibuJack
Yes, around 13 volts.. below 12v if you go below 1000rpm..
I think if you increase the value, you compensate MORE for latency so it adds more fuel essentially.. I may have it backwards since its been a few weeks since I tried this.
#33
Ok so I'm making myself some little "charts" to go by when adjusting some of these settings. If you think these could prove useful let me know. It will be interesting to see what is working for people.. I can adjust the chart as more info comes in. This is only the 11.72 column.
Injector Battery Voltage Latency 11.72v column
Percentages used
0.0336 5%
0.0672 10%
0.1008 15%
0.1344 20%
0.168 25%
0.2016 30%
0.2352 35%
0.2688 40%
0.3024 45%
0.336 50%
Percentages decreased/increased
0.336 -50%
0.3696 -45%
0.4032 -40%
0.4368 -35%
0.4704 -30%
0.504 -25%
0.5376 -20%
0.5712 -15%
0.6048 -10%
0.638 -5%
0.672 BASE
0.7056 5%
0.720 7.2% Ralliart BASE?
0.7392 10%
0.7728 15%
0.8064 20%
0.84 25%
0.8736 30%
0.9072 35%
0.9408 40%
0.9744 45%
1.008 50%
Actually this may be useless.. you can't get such fine adjustments once you enter these number into the map. Still was fun lol
Percentages used
0.0336 5%
0.0672 10%
0.1008 15%
0.1344 20%
0.168 25%
0.2016 30%
0.2352 35%
0.2688 40%
0.3024 45%
0.336 50%
0.336 -50%
0.3696 -45%
0.4032 -40%
0.4368 -35%
0.4704 -30%
0.504 -25%
0.5376 -20%
0.5712 -15%
0.6048 -10%
0.638 -5%
0.672 BASE
0.7056 5%
0.7392 10%
0.7728 15%
0.8064 20%
0.84 25%
0.8736 30%
0.9072 35%
0.9408 40%
0.9744 45%
1.008 50%
#38
Hey guys... I got my injectors scaled pretty good. I didnt have much time to mess with it this weekend but I did what Jack said. Scaled them to about 680 and got the cruise trims around 14.5-15.2 A/F. Still taking about 20% of fuel out with the SAFC but I think I will have to do it in the flash because closeloop is messing me up because I will run like 17-18 A/F which of course retards timing while crusing. Idle I used the Latency Battery to add a tad more V @ idle. Still gotta do more but Im almost done
#39
at 900-1000 you should see around 12-13 volts... nothing a bit of logging can't give you though.. every car is different..
#44
No its actual battery voltage.. It really only makes a difference if your car idles below 1000rpm.. If its around 1000 or so, it seems to be around 14 volts (I checked this last night) But it does "Tween" the values, so you should be adjusting the desired cell plus the one above and below..
#45
well actually if you check the AEM injector wizard.. they put the latency for the 75lb injectors at
9v 1.32
12v 0.72
14v 0.54
16v 0.37
so your 12 and 16v is close ..
then again they put stock Evo injectors at 0.9 at 12v
9v 1.32
12v 0.72
14v 0.54
16v 0.37
