evoscan logger release
#151
Originally Posted by Cannonballer
Wouldn't boost logging require the installation of an additional sensor of some sort? I was under the impression the stock ecu had no idea what actual boost was, instead it used an calculation of some sort to approximate...
#155
I dont know if my friend who was messing with my laptop accidently deleted the program or what. When I try to open It asks me for the installation package folder where EvoScanv0.7.msi is. It was working fine yesterday. Evo4mad I guess I need the program agian to reinstall. Ill PM you
#156
TPS sensor simply isn't zero volts with a closed throttle. There is an ISCV which allows the car to idle.
You're unlikely to find unused ADC inputs on an OEM ECU, and even if you did they would need the ECU code adjusted to read them. Would be best to use another device to log external sensors and allow the same software to read that and incorporate the results into the stream.
#160
im wondering if there is a way to create a load % value logger so that it could be directly compared to the ECUFlash maps...that would be da shiznit.
edit: nevermind https://www.evolutionm.net/forums/sh...hreadid=209541
#162
Originally Posted by gsrboi80
I tried to repair it but it still gives me the same message it needs Installation package containing EvoScanv0.7.msi
HELP ME
HELP ME
The software is Rar'ed with 3 files. The .msi file is one of them. Just email Evo4mad and have him resend you the RAR file. I can send you a copy of the software if you wanna wait til I get home from work
