evoscan logger release
Originally Posted by elhalisf
guys, i cant believe your even THINKING that he is running a scam. i have personally seen the software and can guarantee its existance.
He emailed the update.
this may be a dumb question but how do you save a log to file? Also, is anyone else seeing over 260 degrees F all the time for coolant temp? The timing advance was a lil off too. I was seeing over 31 degrees at WOT @ 6500 rpms in 3rd. I hooked up my scan tool and coolant temps never over 190 and timing advance under WOT never got above 18 degrees which is where it is set. Just wondering.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Originally Posted by 05BlackEVO
this may be a dumb question but how do you save a log to file? Also, is anyone else seeing over 260 degrees F all the time for coolant temp? The timing advance was a lil off too. I was seeing over 31 degrees at WOT @ 6500 rpms in 3rd. I hooked up my scan tool and coolant temps never over 190 and timing advance under WOT never got above 18 degrees which is where it is set. Just wondering. ![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Is anyone else having a problem with the NETframework requirements? I've already long since updated to 2.0, but it seems like it requires an earlier version to run EVOScan and it won't even install for me.
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Originally Posted by colonelfox
Is anyone else having a problem with the NETframework requirements? I've already long since updated to 2.0, but it seems like it requires an earlier version to run EVOScan and it won't even install for me. ![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
