Windows XP works fine Windows 2000 i got problems
I need a little assistance here guys... After about 4 hours of battling this issue out, i turn to you guys for some help. I have windows 2000 on my dell and everything from the software to the drivers get installed correctly according to the prompts but when i try to read my stock rom i get:
[03:49:46.724] Version 1.28.716
[03:49:46.774] 8 memory models read.
[03:49:47.945] 71 ROM metadata models read.
[03:49:47.945] checksum module "subarudbw" loaded.
[03:49:47.995] flashing tool "wrx02" loaded.
[03:49:47.995] flashing tool "wrx04" loaded.
[03:49:47.995] flashing tool "sti04" loaded.
[03:49:47.995] flashing tool "sti05" loaded.
[03:49:48.005] flashing tool "mitsukernel" loaded.
[03:49:48.005] flashing tool "mitsukernelocp" loaded.
[03:49:48.005] flashing tool "mitsubootloader" loaded.
[03:49:57.569] sending init sequence 1 (0001)
[03:50:00.824] sending init sequence 1 (0003)
[03:50:14.063] sending init sequence 1 (0003)
[03:50:25.279] sending init sequence 1 (0003)
[03:50:28.383] sending init sequence 1 (FFFF)
[03:50:31.648] sending init sequence 1 (0001)
[03:50:32.680] got 0x05 response
[03:50:32.680] sending init sequence 2
[03:50:32.690] got 0x1B response
[03:50:32.700] sending init sequence 3
[03:50:32.770] error sending init sequence 3
[03:51:29.201] sending init sequence 1 (0001)
[03:51:30.222] got 0x05 response
[03:51:30.222] sending init sequence 2
[03:51:30.232] got 0x1B response
[03:51:30.242] sending init sequence 3
[03:51:30.653] entering bootloader
[03:51:30.673] sending kernel size (3392)
[03:51:30.703] sending kernel load address (0xFFFF8800)
[03:51:30.753] uploading kernel
[03:51:31.054] error transmitting kernel
[03:51:43.311] sending init sequence 1 (0001)
[03:51:53.145] sending init sequence 1 (0001)
[03:52:03.410] sending init sequence 1 (0001)
[03:52:11.201] sending init sequence 1 (0001)
[03:52:19.133] sending init sequence 1 (0001)
Being frustrated and all, i borrowed my sisters new Sony VAIO with Windows XP and installed everything on her laptop. Without hesitation BAM it synced up and it was all good. Only problem is that its not my laptop and i cant access it anytime i want. I had everything from file paths to com ports in my laptop set correctly and still NO GO on Windows 2000. Are there any differences between the 2 OS that is screwing up the install?
i have tried both removing and re-installing through the device manager and it still wont seem to work. That is what bugs me most is that i know it should work for the windows 2k pro but for some odd reason its not communicationg properly. I tried connecting to the logging software but that didnt work either. Maybe i should try removing all the files including logging software and try re-installing everything again.
i finally got it........ i had to re-install the programs under the C drive into the drivers folders. It was installing into the program files the whole time which i thought was correct but i guess i was wrong. Its all good now!
That's good to know if I run into problems with my old
windows 2000 powered Fujitsui laptop with a Pentium 133.
damnnnnn................ its happening again. The same thing that was happening in the program file is happeing in my drivers program now. I tried removing and re-installing again there, but no luck. What do you guys think is happening
