MIVEC tuning
Old Oct 19, 2006 | 10:24 AM
  #151
JohnBradley's Avatar
Looks almost identical to an RS except for the high rpm advance. I suggest that if you are gonna try that as I have...bump it to 7.2*
Old Oct 19, 2006 | 11:13 AM
  #152
thatsMR2u's Avatar
thanks for the advice john! and it works out great in the car- it holds boost impressivly well for just using the stock boost solenoids with modified maps- and with the timing going for 7 to 6 to 5 at boost spike then back up to 18 by redline the car barely ever gets even one count of knock at 21 psi
Old Oct 19, 2006 | 03:18 PM
  #153
Ralph's Avatar
Wow 18 degrees at redline ?
Old Oct 19, 2006 | 03:27 PM
  #154
-=SPECTRE=-'s Avatar
i wonder how much boost at redline? i guess the tradeoff is: more timing less boost or less boost more timing? which one will produce the most power?
Old Oct 19, 2006 | 03:49 PM
  #155
Ralph's Avatar
I don't know what boost I pull at redline but its near 200 load.. I can barely muster 15 degrees, sometimes 16 degrees at redline.. before it'll knock -_- 91 octane though
Old Oct 19, 2006 | 04:29 PM
  #156
that's a fair amount of timing for an EVO IX at redline. my car runs less than that on 93 and a couple of other 9's I know of also run less than that. I'd be curious to know what boost you make at redline - I'm consistently at 17.8-17.6psi at 7600rpm in third or fourth gear.
Old Oct 19, 2006 | 05:44 PM
  #157
thatsMR2u's Avatar
yaah the zeitronix system is extremely bad **** for datalogging boost- but his boost seems to spike to about 22 and taper to 18 right at redline with timing numbers such as
RPM Timing
2000 7
2500 7
3000 6
3500 6
4000 5
4500 7
5000 8
5500 10
6000 12
6500 13
7000 16
7500 18
but also a deterant to knock is probably the fact that by redline his a/f ratios are right around 10.8-10.9 in 4th gear at redline
spectre what are u using to control boost
Old Oct 19, 2006 | 05:49 PM
  #158
thatsMR2u's Avatar
200 load u would be able to run that much timing because its only around 1 bar 14.7psi - check for a boost leak u should be in the load cell 240 at redline or just falling back into 220 at about 7000rpms and up
Old Oct 19, 2006 | 05:52 PM
  #159
thatsMR2u's Avatar
ohh btw the timing numbers i posted above are for load column 220 - 240 is a tad bit less aggressive
Old Oct 19, 2006 | 06:57 PM
  #160
Ralph's Avatar
Can I get a second opinion on this ? Anyone know what Load you get at redline when running higher boost (22-23)?
My gauge doesnt sit at 0 at idle, crappy autometer. I'll glance at it tonight when I modify the map. Usually I'm too busy watching RPM XD Don't wanna bounce off the 7800 limiter for more than a second, if at all.
Old Oct 20, 2006 | 10:02 AM
  #161
Forge UNOS
Old Oct 21, 2006 | 09:00 AM
  #162
High_PSI's Avatar
Hey Ralph I was wondering if you had run a Map supplied by JohnBradley on your Stock IX? I was wondering your opinions on that. Also John if you could shoot me a PM I am having issues loading that very same map, probably something stupid but I would like your input if possible.
FYI I wana flash a 100% stock Evo IX to get the most out of it and keep a Warranty for a While.
Old Oct 21, 2006 | 09:57 AM
  #163
I think you would be best off deleting the map I sent you and send your ECU to DynoFlash, TTP, Ivey, etc.
To answer your question, there is no way to load only the low octane or high octane portion of a map. It doesnt work that way. The low octane is a safety net in case the car is malfunction/inaccurately tuned.
Old Oct 21, 2006 | 12:06 PM
  #164
High_PSI's Avatar
That's all i was asking, no reason to assume I can't understand or tune this. It is just a new interface for me. I again appreciate the map you gave me, I just find the system a little vauge to work with and juts need a little pointers.
Old Oct 21, 2006 | 02:08 PM
  #165
Ralph's Avatar
Yes I have a tune centered around that mivec map, I'm not sure how it will compare to the few other tunes I've got. I'll be testing these next weekend at the track.. comparing trap speeds etc and see which gives me the best times . (Theres no AWD dyno within 2 hours of here)
Quick Reply: MIVEC tuning
