MIVEC tuning
Old Aug 17, 2008, 09:24 PM
  #511
Jeff_Jeske's Avatar
The stock flash would be terrible for 25psi. It pulls timing and floods the engine with fuel. I wouldn't run more than stock boost until I got a different tune on that thing.
Old Aug 17, 2008, 10:32 PM
  #512
brandEvO's Avatar
it shouldn't be at 25psi, I don't even have a MBC on it.
Old Aug 18, 2008, 07:12 AM
  #513
Mojo Rising's Avatar
I would try to locate the stock rom and compare the two. also check to see if there is a MBC somewhere hidden. As for the rev limit, you might want to check your lower clutch switch. See if it was unplugged or adjusted improperly.
You should actually start your own thread for this, as it is OT to mivec tuning, really. Hope I could help.
Old Aug 18, 2008, 11:06 AM
  #514
brandEvO's Avatar
Thanks for the information. I actually started a thread for it.
Old Aug 21, 2008, 10:53 AM
  #515
kanscooby's Avatar
Originally Posted by dudical26
Does any one know of any other tech articles that discuss the advantages of advancing and retarding cam timing?
Hi all,
I pulled this off the Service Manual, hope it helps.
File Type: pdf
File Type: pdf
poyz (Nov 29, 2016)
Old Aug 21, 2008, 06:48 PM
  #516
ecuflasher's Avatar
Very nice
Old Sep 30, 2008, 10:25 AM
  #517
lemmonhead's Avatar
what about MIVEC if your using meth injection. should you just leave the MIVEC alone if switching from PUmp to racegas?
Old Nov 15, 2008, 08:07 AM
  #518
51
51's Avatar
Just read through the whole thread & see a few say that anything over 28.8 is going to just read 28.8 & some say you can go up to 30.0 max. My question is this - Under MIVEC Intake Advance Max it shows 28.8 if I change that to a different number will that has any affect at all? Could this be some kind of a limiter for MIVEC?
Old Nov 15, 2008, 08:44 AM
  #519
mrfred's Avatar
It is a software limiter, but there is a hardware limit of 28.8 deg. If you set the software limit to 30 deg, MIVEC will still not exceed 28.8 deg.
Old Nov 15, 2008, 07:58 PM
  #520
51
51's Avatar
Thanks
Old Jan 23, 2009, 06:17 PM
  #521
nikkadanny's Avatar
hey does any one have a good mivec map for the brian crowers 272s? i know they suck but i got to get them to use b4 i get some kelfords or cossies
thanks
btw, im even with a car equiped with kelfords 280/272 9 with these cams....
Old Jan 23, 2009, 09:33 PM
  #522
lemmonhead's Avatar
post up your meth injection MIVEC maps.
Old Jan 24, 2009, 02:02 AM
  #523
Jeff_Jeske's Avatar
I doubt they will be any different than the race gas maps.
Old Jan 24, 2009, 08:44 AM
  #524
mrfred's Avatar
+1. High load tunes for a particular turbo should all have similar MIVEC maps.
Old Jan 24, 2009, 09:25 AM
  #525
lemmonhead's Avatar
you say High load, what about low loads?
and I cant really see meth/water MIVEC being same as race gas MIVEC since there is huge temperature difference between the two, combustion rate and properties post combustion.
intuition tells me that both cant be the same, but as we all know intuition is not always right.
Quick Reply: MIVEC tuning
