innovate lm-1 interface
I see that Evoscan is now incorporating the use of the innovate lm-1 or lc-1. My question is what pinout on the ecu is used to connect the output of the lm-1 so that it can be seen through Evoscan?
I have the UEGO and I was curious as to this also. I know I can use a serial connector and a serial to USB convertor with HyperTerminal to log AFR, but I havent tried anything with EvoScan to see how it integrates.
The LM-1 or LC-1 is connected to the laptop via a serial or usb connector via a virtual port since the Innovate products use the serial connector. The EvoScan software takes that data and records it with the data coming off the OBDII port.
Originally Posted by spoolinspyder
well, i guess we have to wait until the fix is out for the innovate. By the way how would the
obd port read outputs of the LM-1 through the laptops serial cable.
jbergmeier
Mar 2, 2009 05:57 PM
