ROM definition for ECU
Originally Posted by elhalisf
i have the same ecu number. i opened it as 96420008. the only difference is the idle step lookup table, where the scaling is all screwed up. leave that as is.
Originally Posted by Ludikraut
Why don't one of you post up the ROM(s) in question - either here or on openECU.org. I'm sure it won't be very difficult to fix the XML definitions.
l8r)
l8r)
When I open up the ROM with ECUedit, I can see alot more fields than under ECUFlash. So basically, I just want to use the fuel/ignition maps without worrying about the other undefined fields messing up the ECU when I reflash it.
Tien Sebastian
Lancer Engine Management / Tuning Forums
Jun 13, 2021 12:26 AM
