Coolant Temp and EvoScan
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
I noticed what seemed like high coolant temp values on a couple of logs. This morning, I started the car and logged as it warmed up. The logged value from EvoScan at "full operating temp" was showing as 206.9024F. The factory gauge reads as normal.
I have logged the car with a PocketLogger before and recall "full operating temp" as being closer to 180 - 190F so it looks like my displayed value is about 20F off.
Is anyone else experiencing the same thing? I know one person mentioned similar results here.
Has anyone compared to a PocketLogger to check the value from EvoScan?
Yes, they are off. I think you have to subtract -10 from the coolant temp value. and oxygen sensor reading is off too. you have to add +.1 to that. well... it was the result of experimenting with my pocket logger and evoscan.
Originally Posted by TTP Engineering
How tough is it to change the XML formulas?
now the question is what new value or multiplier is the correct one to use???
looks like that Eval formula is screwed.
Someone gotta know the right way to translate to Fahrenheit from this register reading.
LogReference="CoolantTemp" RequestID="07" Eval="((-1.468x+139.74)*1.8)+32"
Okay, try this formula instead. I think it should be around right range if original formula was the close one.
Find this line LogReference="CoolantTemp" RequestID="07" Eval="((-1.468x+139.74)*1.8)+32"
and replace Eval with
Eval="((-1.468x+134.18)*1.8)+32
or
Eval="((-1.645x+139.74)*1.8)+32
Let me know which one works better
or
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
had 2 revive this 1 as Im experiencing the same issue. 203*F @ idle...
Just had a turbo and o2 (recirculated) installed today.
Last time I logged coolant temp, (while back) it was ~ 180 ish @ idle and have seen 162*F while cruising/on dyno, but wouldnt go lower than 188*F tonight while cruising. (~50* outside)
temp guage on dash is normal.
MUT 07 (0x6A47), Eval = "x*1.8+32", metric eval = "x", unit = "deg F", metric unit = "deg C", guage/chart min/max = 190
does this look about right?
