Boost Control using Max Wastegate Duty #
Old Sep 9, 2006 | 03:57 AM
  #61
heyzeus11's Avatar
Originally Posted by Evo_Kid
2) When it was cold tonight, the boost would spike (which is normal), but after the spike it seemed like the ECU was tring to correct the spike but would pull too much WG duty cycle and boost would go too low (underspike??).
I've been messing with the turbo error correct to try and fix it but I still dont understand it.
If anyone could tell me how it works, I'd be on my way to figuring out how to have complete boost control using the stock boost solenoid for pump gas boost and race gas boost.
try increasing your boost load target through the rpm range that your "boost would go too low"; and see if that gets your boost up. my guess would be that with the colder air your car can run less boost to reach its boost load target; if im wrong im sure someone will correct me.
Old Sep 9, 2006 | 08:24 AM
  #62
JohnBradley's Avatar
You can also 0 the boost error correction table to keep it more consistent. Then as long as your WG is curved the way you want it, you shouldnt see any more underspikes.
Old Sep 9, 2006 | 10:25 AM
  #63
mrfred's Avatar
So, Im having two problems with my new restrictors setup.
Have you considered using a bleeder rather than a restrictor pill or in conjunction with a restrictor pill?
Old Sep 9, 2006 | 11:13 AM
  #64
In my opinion this is the most effective way to cure taper (because it retains electronic control of boost), it also happens to be the least expensive.
Old Sep 9, 2006 | 01:26 PM
  #65
Evo_Jay's Avatar
What side of the error correction table should be 0'ed out, the left or right side.
Old Sep 9, 2006 | 06:51 PM
  #66
mrfred's Avatar
The right side which is the amount of correction that the ECU attempts to apply.
Old Sep 10, 2006 | 02:35 AM
  #67
Evo_Jay's Avatar
Well, I got complete boost control using the stock boost solenoid almost worked out.
Just have to test stability, test race gas boost, make some logs and write a how-to.
Hopefully, Ill have it all worked out by the end of this week.
Old Sep 10, 2006 | 03:51 AM
  #68
mchuang's Avatar
Just the way AEM works when you use it with a GM boost solenoid. I use to have AEM on my honda and would just control boost with wastegate duty cycle map..
Old Sep 14, 2006 | 10:48 AM
  #69
andenbre's Avatar
that would be great I spent some time on this but didnt have the time to work out the same issues you were having. (big family)
Old Sep 16, 2006 | 11:55 PM
  #70
mlancerevo8's Avatar
If you want to do it entirely with software just set all boost load tables to 159.4 and wastegate duty cycle to 127.5, and boost limit to 319
However thats not really what this thread is about. You can be more accurate by doing some mechanical changes and then curving the maps for what you want.
Sometimes finesse is better than brute force, consider that helpful advise.
i have a evoVIII im running a perrin mbc wondering if it would be the same for my software to do the same .... if not please post me the formula
S15me2
Dec 8, 2016 09:22 PM
kons6
May 26, 2016 03:41 AM
TTP Engineering
Evo X Dyno Results
15
Aug 4, 2009 10:59 AM
cij911
Nov 26, 2006 03:45 PM
TonyG
Apr 10, 2004 08:24 PM
