35r and EvoFlash. Lets see what happens...
Well here you have it, I am in the process of ordering my SlowBoy Racing GT35r turbokit. Keeping the stock bottom end, stock intake manifold, ad see how much it will make on the stock ECU. this is my DD so i dont think that AEM is my answer yet.
Theres alot of members making good power but no guide to do it in step so hopefully i'll provide you guys asking some questions based around this topic with some answers.
Anthony
Boston Dyno
Parts list so Far.
Slowboy Racing GT35r Turbokit SBR 35r Turbokit
Neisi FMIC
ARP HeadStuds
ARP Rod Bolts.
ACT HDSS Clutch Kit
Fidanza Flywheel
Brian Crower Springs and Retainers
Comp Cams 280s
FIC 850 CC Injectors
OEM Mitsu Exhuast Manifold Gasket
Walboro 255
BR STS
BR Shifter Bushings
BR Front motor mount
RNR Downpipe
RNR Testpipe
MR catback
AMS Rear Control Arm Bushings ( this has nothing to do with the motor but Hey better launching right ?)
NKG BP7ES
SBR Upper Inter Cooler piping
Tial 50mm BOV
AEM Wideband.
AMS/Fuel Lab Fuel Pressure Regulator Kit
EVO Scan 0.9 Pre Release
Ton of other mods, Just not listed but this is what i got so far off the top of my head.
In the Future/ Upcoming mods.
SMC Trunk mount Alky kit
port and polish intake mani,Head, Throttle body
more to Come just getting Started.
Anthony
Boston Dyno
Parts list so Far.
Neisi FMIC
ARP HeadStuds
ARP Rod Bolts.
ACT HDSS Clutch Kit
Fidanza Flywheel
Comp Cams 280s
Walboro 255
BR STS
BR Shifter Bushings
RNR Downpipe
RNR Testpipe
MR catback
NKG BP7ES
Tial 50mm BOV
AEM Wideband.
I am running a RNR 35r kit with a EvoFlash done by TTP-Engineering. Also I am running 100% Meth. You will enjoy the car. Also my car is my daily driver as well. Good luck with your set-up.
Originally Posted by LuxuryBroker
Smogrunner is running that set up and seems to be working for him.
Terry S
i think its great that theres more people like me, but i wanna create a guide for others that wanna run a similar setup using the stock ECU. standalone isnt for everyone. like a tuning guide some basemaps to get people started. Mods/parts list. Cheap little fix its and tweaks. One thing i hate about this forum is that people are too quick to throw there money around and not really do the HW to get what they want. maybe i just have some of the old school dsm in me still.
i am doing the same on our shop car...
2.3 liter JAM block..... JAM stage 3+ head with oversized valves, dual springs, etc.... port/polish etc etc....
GT35R .63 (for now)
going to be on stock ECU....
with our own dyno going in soon, im excited to see the data, and i can do testing first hand for you guys....
Cheers
cb
GT35R .63 (for now)
Cheers
cb
I just want to thank all the folks like Malibu Jack, Ludikraut, and Alfred at Tuning Technologies for all the help they have been. We think we can get my car to run consistent 10.8s at about 130mph with no further modifications, just tuning. The following adjustments need to be made:
1. Fuel: we need to do a few logs to make sure my injectors are not completely maxed. I run AMS 880cc. We have already added a second Walbro and have upped the base idle fuel pressure from around 43 to a little over 50.
2. More boost: the 11.0 at 128 was run at 31.6psi. Obviously I have a few more pounds of boost on tap. It is just a matter of not overrunning other systems (fuel and spark)
3. Shift knock. Alfred is on top of this issue. We are getting little or no knock except at shifts, which has caused the car to momentarily sputter on my 2-3 and 3-4 shifts. We aren't even sure if this is real knock, but this killed me on my best run ever where I did a 7.1 at 99.66mph in the 1/8th only to finish with an 11.013 at 125mph. Alfred feels that there is too much ignition advance in my table at the lower load points which are active during shifts, so he is gonna adjust those fields to create less of a dramatic change during shifts.
4. When I did the 11.0s, we hadn't tinkered with rescaling the load values from 260 to 300. We just tuned with the stock values.
What do you guys think?
I just installed my AMS 35R kit today and will be contributing to this as I begin the tuning process. I installed the kit out of town in a friend's shop, so I'm using the stock injectors until I get home and can tinker. It'll be fun to have a stock injector tune anyway, so I'm going to tune them out as well.
First impession is that the car feels very different and the exhaust note doesn't sound nearly as nice as it did w/ the stocker. Spool time will decrease as I get AFRs out of the 9s/10s during spool up
Smoggy, I think you're going to have to rescale well beyond 300. I just upped my boost to a measly 22-23psi and I am now consistently hitting load values between 280 and 290. I can only imagine what your 2.3/35r combo would hit on 32psi of boost.
l8r)
l8r)
l8r)
l8r)
0 10 20 30 40 60 80 100 120 140 160 180 200 220 240 260 280 300 320
I don't want to go higher than 320 because the car actually runs really great even with the stock 260 scaling.
