OBD Scan/Reset software for OpenPort cable?
I have the OpenPort cable for using EcuFlash and EvoScan. Is there a compatible software for this cable to read and reset the CEL?
As a backup plan, if the CableTools control and tester I put out as open source for the OpenPort cable will establish an OBD-II connection with the ECU, I have a little utility I wrote for my own use that can be used to check and reset diagnostic codes I'd be happy to post. It's awfully crude though.
-jjf
FWIW, that tool looks pretty complete, though I've had difficulty getting it to connect to several vehicles. Looking with a scope it seems that some of the software generated timings are a little off (and some ECUs are very picky).
-jjf
-jjf
Uh, well the built ActiveX control and little test app can be downloaded here.
Hit the "Find" button to see if it is compatible with your OpenPort cable. Then pick OBD-II and press "Connect". If it can connect, I'll post the trouble code tool.
However, you might also want to check out the ScanTech tool that MJ is now supporting. If it connects with your ECU, it is a lot more complete than mine.
As for any other tools, well, you folks are on your own...
-jjf
-jjf
The control test just lets you know if an ODB-II connection can be established. There is a seperate little crude snapshot/clear/test app.
That source is also making the rounds, so hopefully someone like Malibu Jack can improve upon it.
-jjf
-jjf
WTB[MidWest]: Tactrix Cable
Evodetailer123
Oct 3, 2016 07:37 AM
Evo Pete MTL
Lancer Engine Management / Tuning Forums
Nov 29, 2012 06:08 AM
