Locked out of my ECU
Old May 31, 2010, 11:43 AM
  #31
Danieln's Avatar
By "locked rom" you mean that you can`t see the tables or you can`t make the modification it it?
Old May 31, 2010, 01:59 PM
  #32
GottaZtt's Avatar
yes sir
Old May 31, 2010, 10:08 PM
  #33
Danieln's Avatar
You`ve got PM
Old Jun 1, 2010, 02:10 AM
  #34
GottaZtt's Avatar
great community thanks for all the help!
Old Jun 1, 2010, 08:52 AM
  #35
Danieln's Avatar
evo7 JDM 2001
Old Jun 1, 2010, 09:20 AM
  #36
rawkus's Avatar
Originally Posted by GottaZtt
this is the rom i am needing to unlock.
It's not that you are locked out, it's that you do not have the proper XML for this rom (with is a 99860002). Attached is all the info I could find about this rom, but I would switch to a different rom as this fuel maps aren't well defined. Take the attached file, remove the .txt suffix and replace with .xml and then save this new XML in you Rom Data folder for EcuFlash.
If this doesn't make sense, please let me know.
Also, I would highly suggest switching to a 90550001 rom and I can help you with that if you'd like, but I would need more information. Hope this helps!
Dan
File Type: txt
  #37
rawkus's Avatar
Originally Posted by Danieln
evo7 JDM 2001
BTW, do you have better definitions then the one I attached? Thanks!
Dan
Old Mar 26, 2011, 10:22 PM
  #38
03Silver's Avatar
Hey guys I have a 2003 Evo 8 and for some reason I can't read it anymore. The only thing I did was change the battery of the car to a brand new one. Even with unlocker started I still can't read or write to my ecu via ecuflash. Any help will be appreciated
tscompusa
Dec 7, 2016 03:31 PM
Dnasario
Jan 16, 2016 08:52 AM
Mr.IX
Nov 22, 2010 09:13 AM
EndlessRed
Apr 3, 2010 10:23 AM
goofygrin
Aug 7, 2009 06:26 AM
Quick Reply: Locked out of my ECU
