Evoscan / Computer help
I downlaod and run the installer and it says:
This setup requires the .NET Framework version 1.1.4322. Pleas install the w/e and run again.
So i follow the link to here.
http://msdn2.microsoft.com/en-us/net.../aa731542.aspx
and download and install the software development kit and the redistributable Package
x86 version
It still will not let me run the installer.
x86 version
Thats cause that link most likely installed v2 of the framework (that's where that link went to). Do me a favour and do this
Start->run
Type in
"%windir%\Microsoft.NET\Framework"
And tell me what folders starting with "v" you see there. You probably have a v2.0.xxx folder but not a v1.1.4322 folder (simple way to check what version you have installed.
Flaw in how the program is compiled. Needs to be recompiled to use the updated v2 libraries. This alone means this program will not work on x64 machines since the first Framework for them is v2.
Here's the link to V1.1:
http://www.microsoft.com/downloads/d...displaylang=en
So what you'll need to do is uninstall the v2 Framework....install the 1.1 Framework (from the above link). Run windowsupdate and see if it picks up the 1.1 Framework SP1 update and the V2 update...if not then pick up the 1.1 SP1
from here:
http://www.microsoft.com/downloads/d...DisplayLang=en
and then re-install the V2 Framework (run windowsupdate to ensure all the various .Net updates are installed). That should allow the program to work.
BTW you don't need the SDK you only need the redistributable.
Start->run
Type in
from here:
Originally Posted by coolguycooz
the best and easiest way to do it is. Go to windows update, and find it under the software updates. Its there, if its not its already installed.
1) If he's installed the newest .net (v2) when windows update does it s check it would say he had the newest one and thus not get the one he needs (in this case 1.1)
2) Even if it got the one he needs not installing the frameworks in the order they are supposed to be installed could cause the incorrect framework to be registered. That would be mean that some .Net programs would work and other's wouldn't.
It sucks that .NET 2.0 doesn't have all the backward compatible calls for 1.1..
Only here's the catch, all code should work on 2.0 when its compiled and the computer your developing on, has 2.0, you just remove the 1.1 references and add the 2.0 ones back in..
AFAIK I think Evo4Mad is using an older development platform which has Developer Studio 2003 and .NET 1.1
He really should be releasing versions that use the newest .NET now that microsoft isn't deploying the older versions anymore with windows update.
Start->run
Type in
Start->run
Type in
edit: i'm just gonna go ahead and try reinstalling everything .
