Is there any Closed Loop Adjustment in Ecuflash?
Originally Posted by Dominos
If your fuel trims are are low then you are really not going to get any town mileage. Even still I don't know how you are going to command a leaner than 14.7 A/F.
If you really want control of all the fueling, then shut down the closed loop function all together. Run it off the base map
sorry .. missed this thread for some reason (on purpose maybe )
MJ, yes joy in sharing .. but like you I don't really see the point in altering the close loop mapping and you're liable to damage the engine easier if you modify that (yep, I got cruise knocks when I was meddling with the close loops which is quite bad)
What I ended up doing was I modified the open loop map and ran totally in open loop once I'm off idle
I figure that since the volkswagon and some other high tech cars are using WBO2 to run in open loop all the time as stock , why can't I do the same with my WB ??
its a PITA as I have to map the entire map from low rpm high load regions to high rpms high load regions very CAREFULLY .. not to mention transition loads!!
I cruise on the highway around 15-16 AFR with a slight gain in MPG with this setup..
and since I'm in open loop most of the time .. my fuel trims are always very close to 0%
If you have the info, you should post it anyway. Most people want to figure it out for themselves on whether or not its worthwhile. Going from 14.7 to 15.0 or so netted no real gains whatsoever on my car. And forcing open loop all the time essentially turns your EFI into one big programmable carburetor that is incapable of adapting to changing weather and other conditions.. Its a catch22 no matter how you look at it.
And I think you have it backwards, some Volkswagon, Porsche and other cars are using wbo2 sensors to run closed loop feedback all the time, using target AFR and cylinder pressure detection and active detonation algorithms for timing to always run closed loop regardless of engine load. Unfortunately it can be a double edged... Its really something all ECU's should have always done, but its only in the past 10 years have PCM/ECM technology advanced to the point where their fast and reliable enough to do that.
I am working on installing an aftermarket EFI system on my supercharged malibu that is capable of Lambda control, but it still uses timing maps though that can be added on to with a failsafe device.
Oh and before someone mentions automapping/auto-tuning ECU's like the Autronic.. That is a tuning method and not a closed loop control, it is a mode that uses wideband signal to read AFR and meet a target, then updates the maps accordingly, you still end up with maps and open loop fuel control under load.
