What timing are you running for peak torque and max RPM
Originally Posted by razorlab
It's obviously not correct, they should also be looking at their timing (if no knocks) and see what load column that falls into.
Code:
240 260 280 300 3000 -2 -3 -3 -4 3500 2 0 -1 -2
I consistently hit -2 deg and sometimes -3 deg across 3000-3200 rpm with no knock in that rpm range. I have many logs showing this. I tinkered quite a bit with the logging order of IPW, AFRMAP, and battery voltage so that the calc load value was +/- 5 points of the ECU load for values below 159. I'm confident in saying that I'm hitting 270-280 load at 3200 rpm. I'm at 300 ft elevation. 4th gear from 2500-7000 rpm for the logs.
Just quoting the FSM here so it's not my uneducated opinion. "ECM advances timing (load decrease) at higher altitudes for more performance"
Also, engines are less prone to knock up thar in them hills which allow the timing to accomidate for the drop in power at elevations
Mine are 3rd gear loads (290-300) at peak torque
Three different logs, peak Torque
TPS...RPM......AFR....Knock..Timing...Load
100...3718...11.70...2........-1..........289 - Has since been dialed in correctly
100...3688...11.20...0........0...........303
100...3469...11.88...0........0...........293
Peak torque varying cause I started at different RPMs..
mods: 93 octain, 24psi spike dropping to 21 by redline, 10.5 hotside, ebay o2, ebay FMIC, ebay TBE w/ testpipe
220 240 260 280 300
7 5 4 4 3 - 3000RPM
7 6 5 4 3
8 7 6 5 4
8 7 6 5 4
8 8 7 6 5
9 9 8 7 6
10 10 9 9 8
11 11 10 10 9
13 13 11 11 10
16 15 13 13 12 - 7500RPM
17 16 14 14 14
220 240 260 280 300
7 5 4 4 3 - 3000RPM
7 6 5 4 3
8 7 6 5 4
8 7 6 5 4
8 8 7 6 5
9 9 8 7 6
10 10 9 9 8
11 11 10 10 9
13 13 11 11 10
17 16 14 14 14
220 240 260 280 300
7 5 4 4 3 - 3000RPM
7 6 5 4 3
8 7 6 5 4
8 7 6 5 4
8 8 7 6 5
9 9 8 7 6
10 10 9 9 8
11 11 10 10 9
13 13 11 11 10
17 16 14 14 14
220 240 260 280 300
7 5 4 4 3 - 3000RPM
7 6 5 4 3
8 7 6 5 4
8 7 6 5 4
8 8 7 6 5
9 9 8 7 6
10 10 9 9 8
11 11 10 10 9
13 13 11 11 10
17 16 14 14 14
According to evoscan .97 I'm also crossing 300 load around peak torque in 3rd gear. In 3rd I see peak loadcalcs of around 300 falling off to around 215 at redline. In fourth gear I've seen as high as 340 at peak torque. I don't think those loadcalcs are accurate.
