MAF Calibration
Old Nov 12, 2006, 07:11 PM
MalibuJack's Avatar
Originally Posted by DB Performance
The Subarus use a 0-5v MAF and the table in the ECU covers the entire range with a large amount of data points, so it is helpful for dialing in an intake on those cars.
The MAF table in the Evo maxes out well before the MAF does though. It is helpful for dialing in your part throttle fuel trims though, especially around idle, if you have large injectors or if you have a weird airfuel spike during boost transition that you can't hit with the normal maps.
The scaling of the data and axis for the MAF tables in Ecuflash is wrong, but it is easy to figure out what they should be and change them in the definition.
You really should clarify why their wrong and what needs to be done to fix them. I'm sure its frustrating a few people to drop a nugget of info with no explanation.
You are right though.. When I applied the correct scaling to it, it seems to translate to 2609hz which is about the max a stock MAF reads correctly.. I noticed the error a few weeks back, but never made the connection about the reading..
The good news is you can alter this axis if necessary.. I definitely would like to get some confirmation on whether or not this is indeed correct, which is why I never posted much about it a few weeks ago.
Old Nov 13, 2006, 06:27 PM
eficker's Avatar
+1 for how to fix it.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
therocket
Jun 29, 2010 02:43 PM
nutrulz
AEM EMS
Aug 18, 2008 01:49 AM
l2r99gst
Apr 22, 2007 01:18 PM
bbbwrx
Jun 3, 2006 09:12 AM
Quick Reply: MAF Calibration
