Does this look bad?
Old Dec 2, 2006 | 06:40 AM
boony's Avatar
Does this look bad?
Hi
I've just done a 3rd gear WOT log and it seems lick my stock E8 MR is knocking quite a lot. Is this as bad as it seems to me - I'm a total newbie and would have thought the stock ROM would be very safe/good but to me it looks bad.
Code:
RPM     TPS     KNOCK COUNT
2750	26.27	0
2718	26.27	0
2718	26.27	0
2750	26.27	0
2750	29.41	0
2781	36.86	0
2843	85.49	1
2843	100	1
2906	100	1
2968	100	1
3062	100	4
3156	100	4
3250	100	4
3343	100	4
3437	100	5
3531	100	5
3656	100	6
3781	100	6
3906	100	6
4062	100	6
4218	100	8
4375	100	8
4500	100	8
4625	100	8
4781	100	9
4906	100	9
5062	100	9
5250	100	9
5375	100	9
5531	100	8
5656	100	8
5781	100	8
5843	100	8
6000	100	8
6125	100	7
6250	100	7
6343	100	7
6437	100	7
6531	100	7
6656	100	6
6750	100	6
6812	100	6
6937	100	6
7031	100	6
7125	100	5
7250	100	5
7343	100	5
7406	100	5
7500	100	4
7562	100	4
7718	100	7
7406	100	21
7656	18.04	10
7437	15.69	0
7000	14.12	0
Old Dec 2, 2006 | 06:50 AM
cfdfireman1's Avatar
yes it's not good. but are these stock ecu's or are they modified after they leave mitsubishi? can you log timing and let us see that also? what are you using to log with ecu flash I assume?
Old Dec 2, 2006 | 06:55 AM
BURNALL_4's Avatar
i think its ok its probally normal engine noises, one of the guys at apex-i said on the safc-II anything over 60 you should worry about and your way below that.
Old Dec 2, 2006 | 07:09 AM
SophieSleeps's Avatar
Originally Posted by boony
Hi
Code:
RPM     TPS     KNOCK COUNT
2750	26.27	0
2718	26.27	0
2718	26.27	0
2750	26.27	0
2750	29.41	0
2781	36.86	0
2843	85.49	1
2843	100	1
2906	100	1
2968	100	1
3062	100	4
3156	100	4
3250	100	4
3343	100	4
3437	100	5
3531	100	5
3656	100	6
3781	100	6
3906	100	6
4062	100	6
4218	100	8
4375	100	8
4500	100	8
4625	100	8
4781	100	9
4906	100	9
5062	100	9
5250	100	9
5375	100	9
5531	100	8
5656	100	8
5781	100	8
5843	100	8
6000	100	8
6125	100	7
6250	100	7
6343	100	7
6437	100	7
6531	100	7
6656	100	6
6750	100	6
6812	100	6
6937	100	6
7031	100	6
7125	100	5
7250	100	5
7343	100	5
7406	100	5
7500	100	4
7562	100	4
7718	100	7
7406	100	21
7656	18.04	10
7437	15.69	0
7000	14.12	0
I think it's a little strange how you start seeing knock at 2800 rpm.
And you also go to almost 7500?
Old Dec 2, 2006 | 07:10 AM
Isn't the maximun knock count on evoscan 36?
Old Dec 2, 2006 | 07:48 AM
jcsbanks's Avatar
Max is 36. The 21 and 10 at the end are the rev limiter. The knock sum is not comparable with Apexi products.
Boony, we also need to see ignition timing and octane number at least.
The knock sums aren't terribly alarming if the octane number is half decent. The ECU is doing its job and you can improve all this when you get your wideband, fuel pump and exhaust and being tuning.
Old Dec 2, 2006 | 07:49 AM
boony's Avatar
Hi thanks for answers.
I logged the data with MalibuJack's mitsubishi logger. I've attached the full log. So a knock count of 9 is ok then?
cheers all,
Boon
File Type: zip
Old Dec 2, 2006 | 08:02 AM
jcsbanks's Avatar
I've looked at your log. The ECU appears to be doing its job. Your knock sums are a little on the high side but I don't believe that your engine is being harmed. The octane number goes down a little, this isn't dramatically different from some other logs of JDM ECU cars running on UK fuel like yours is. The JDM ROMs run considerably more timing than the US ROMs.
I prefer to keep the knock sum below 4. When you tune your car you'll be improving things.
Old Dec 2, 2006 | 08:03 AM
evodrivesme's Avatar
ya what gas did you use and what is your timing?
Old Dec 2, 2006 | 08:49 AM
cmz's Avatar
cmz
fwiw, my stock '05 GSR had a fair amount of knock. Up to 10 counts at 7k. It wasn't as consistent as yours. Some knock around spoolup, then it usually degraded and came back in after 5500.
And that's on Sunoco 94.
I decided I didn't like that and got an eflash to clean things up. Much better now.
Old Dec 3, 2006 | 03:14 AM
C6C6CH3vo's Avatar
Octane and timing can change your car considerably, I think
Old Dec 3, 2006 | 04:16 PM
EVO2003VIII's Avatar
I think that you have too much knock; this is my log from yesterday in 2nd and 3th gear
2nd 3th
rpm tps knock rpm tps knock
4312 100 0 5375 100 0
4625 100 0 5593 100 0
4937 100 0 5687 100 0
5312 100 0 5875 100 0
5718 100 0 6062 100 0
6156 100 0 6218 100 0
6468 100 0 6437 100 0
6875 100 0 6562 100 0
7156 100 0 6718 100 0
7437 100 0 6906 100 0
7062 100 0
7187 100 0
7343 100 0
Old Dec 3, 2006 | 04:39 PM
but in 4th gear
rpm tps knock
5406 100 5
5750 100 5
5687 100 5
5781 100 5
5937 100 5
6000 100 4
6062 100 4
6187 100 4
6281 100 4
6312 100 4
6406 100 4
6531 100 3
always try to tunned your air fuel ratio and knock in 4th gear....you will tunned it better
Old Dec 3, 2006 | 08:39 PM
nj1266's Avatar
I ran your log in DLL and this is what it shows. Since your car is stock, the only thing I can think of is bad gas. Here in CA, gas blends are switched this time of year. And in some cases it makes cars knock more than before. Perhaps you have the same thing happening in the UK.
Old Dec 3, 2006 | 08:49 PM
nj1266's Avatar
Originally Posted by EVO2003VIII
but in 4th gear
rpm tps knock
5406 100 5
5750 100 5
5687 100 5
5781 100 5
5937 100 5
6000 100 4
6062 100 4
6187 100 4
6281 100 4
6312 100 4
6406 100 4
6531 100 3
Unless you have been to make your AFR the same in 3rd and 4th gear (something that I have yet to figure out how to do), your afr in 4th gear would be lower than in 3rd gear. So logically, you should have less knock and not more.
Those of us who have not figured how to make the AFR the same regardless of gear, tune in 3rd gear. My car is currently tuned to run @ an average of 11.5:1 in 3rd gear. If I tune it to run the same AFR in 4th gear, then my 3rd gear AFR would be @ around 11.8-12:1 which is way too lean for 93 octane gas that I use.
Quick Reply: Does this look bad?
