EVOScan parameters
EVOScan parameters
It would be very useful to have an accurate description of each EVOScan parameter. I would like to start a list that can be modified to what is agreed upon/proven to be correct. Does this make sense?
Accel Enrichment:
Fuel enrichment based on TPS?
Coolant Temp:
self explanatory
Engine Speed:
engine rpm
Fuel Trim, Low, Medium, High:
long term fuel trim. low, medium, high rpm or load or ??? what are the break points? do the long term fuel trims effect open loop?
Oxygen Feedback Trim:
short term fuel trim. does not effect open loop?
Oxygen Sensor:
main oxygen sensor output, 0-1V narrowband
Oxygen Sensor #2:
secondary oxygen sensor output, 0-1V? EVOScan scales to 5V?
Throttle Position:
throttle position sensor %
Air Flow Hz:
MAFs (Karman Vortex) frequency
Air Temperature:
intake air temperature (from MAFs?)
Air Volume:
calculated air volume? number don't look correct in EVOScan
Barometer:
barometric pressure from MAFs?
ISC Steps:
idle speed control motor
Knock Sum:
filtered knock level, 0-32?
Timing Advance:
self explanatory
Load:
Injector Pulse Width:
injector pulse width in milliseconds. includes latency?
Battery Level:
battery voltage at ECU
AFR Map:
Load Calculated:
approximation to find x-axis in ECUFlash?
EGR Temperature:
self explanatory
Octane Level:
100=high octane maps, 0=low octane maps, in between is interpolated ???
Speed:
vehicle speed from vss
MAP:
calculated boost in kpa using a VE table with rpm & air flow? only accurate for stock cars
Accel Enrichment:
Coolant Temp:
self explanatory
Engine Speed:
engine rpm
Oxygen Sensor:
Oxygen Sensor #2:
Throttle Position:
Air Flow Hz:
Air Temperature:
Air Volume:
Barometer:
ISC Steps:
Knock Sum:
Timing Advance:
self explanatory
Load:
Battery Level:
AFR Map:
Load Calculated:
EGR Temperature:
self explanatory
Octane Level:
Speed:
MAP:
AFRMap:
I noticed that it only changed from a base value of 128 to something higher when I went WOT (so the TPS maxxed). It is also used in the LoadCalc calculation.
MAP:
On my 05 at least, the 'units' don't seem to be Kpa at all. When I was doing a 3rd gear pull, starting at 2k rpms, it maxxed out the MAP reading at 328.16 at ~2300rpms. I'm guessing that was roughly when the car went into boost, so it's equal to a very low boost pressure; say 0-2 psi. So I'm guessing that the MAP reading tells the ecu when to switch from closed loop to open loop operation. Just a bunch of guesses!
MAP:
HiVoltEVO8
49
May 11, 2006 11:50 AM
