ECUFlash / Evoscan / Mitsulogger Questions
#1516
This description (above) doesnt work for me because when i open the *.hex file with notepad i see strange signs wich are not working.
When i open a *.xml file everthing is ok.
Did i do something wrong?
my evo was mapped once. i have no problems with my engine but i want to change a few little things in my fuel map.
would you be so kind and help me. thanks in advance
#1517
Silver Sponsor
no I didn't say notepad... I said notepad++ very different things. or use ultraedit, thats what I use. and press ctrl+H to go to HEx mode, and click ctrl+G to go to the position 0xF52 and press enter. here you will see your ROM number like 8digits, like 24430002. There was a tuning guide floating around somewhere with this in.. I think it is on my www.evoscan.com website under tuning guides.
if you go to
C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\
and open some sample xml files you will see this, this is what ecuflash is matching it to. it actually scans ALL of your xml files looking for a match against your rom/hex file.
<internalidaddress>f52</internalidaddress>
if you go to
#1518
if you go to
if you go to
Sorry but i used the notepad++. now i use the ultraedit! opened the file what i downloaded from my ecu (read from ecu) with evoscan. Searched the 0xF52 in the HEx mode. i think this is the Rom ID 96530006 ??
Please look at my screenshot.
What should i do with this number? i tried to put this Rom ID in the input file download with the evoscan software (Optional ECU Init unlocker code in Hex (i.e. F0F0): 96530006
without succes can not open the file with EcuFlash after downloading with evoscan?
#1519
#1520
Silver Sponsor
@rst89 yeah there is a rom called 96530006 - good work. you passed tuning 101 class
next... download 96530006 from this page http://www.evoscan.com/roms/mitsubishi/
and save it in C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\
then open ecuflash, and open your hex using ecuflash.
#1522
Thanks for taking a look. Happy for any help.
Cheers
#1523
lol
I m proud of myself
i downloaded the 96530006.xml file from the evoscan page and saved it in C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\
then i opened the downloaded file with evoscan (FlashImage_20140306_2006.hex)
Unknow ROM image ???
thank you
#1526
#1527
So i need the base xml file in the same folder as the updated xml file? Is that what's stopping EVOscan from showing the map for the map trace function?
#1528
#1529
Completely new to the data logging/ECUflash community...I have a galaxy tablet and was wondering if ECUflash has an app to run on it instead of a laptop? I know EvoScan has the android tablet but not looking to buy another tabled just for data logging. thanks guys!
