ECUFlash / Evoscan / Mitsulogger Questions
Old Mar 8, 2007 | 01:33 AM
  #151
o.e.boost's Avatar
but how do i get the power/tq graph to work for evoscan 0.98v?...i plug in the numbers
like
3245 lbs (vehicle weight)
214lbs (person/other weight)
24.4in(tire diamer/outer tire not rim)
then i changed
temps to 76 degrees f
and the wind tunnel drag to .95 since i didnt know
--all im getting is an error message..im lost
Old Mar 8, 2007 | 10:17 AM
  #152
marksae's Avatar
I'm currrently logging boost with Mitsulogger right now. I have to convert the recorded value back to RAW, then to voltage, and then to a boost value in excel. Is there a way to make this happen automatically? I guess different MDP input selections can be added in the next version of Mitsulogger?
Old Mar 8, 2007 | 10:47 AM
  #153
MalibuJack's Avatar
you can do custom requests to do the conversion, just log the raw value, then convert it with a custom request like load calc does. All of the request labels are available as variables in the eval function.
Old Mar 10, 2007 | 11:52 PM
  #154
idriveanevo's Avatar
i just downloaded evoscan and i finally got the framework to work with vista but now when i try to install evoscan it askes me to either repair od remove evoscan .98, am i supposed to remove it or whats the deal??? im using ecuflash and i have mitsulogger and they both seem to work fine...
Old Mar 12, 2007 | 11:34 AM
  #155
subaruwrx420's Avatar
Is there a way for the unchecked values in EvoScan to not come up in the log file? It's a pain to hide those columns in order to review the log. I read the entire post, most of it in detail, and couldn't find an answer.
Thanks.
Old Mar 12, 2007 | 05:37 PM
  #156
TTP Engineering's Avatar
You can change the display order and items displayed.
Old Mar 12, 2007 | 06:22 PM
  #157
Mr. Evo IX's Avatar
Wow, I didnt know that the order can be changed.. Just edit the .xml and re-arrange? THANKS!
Old Mar 12, 2007 | 06:38 PM
  #158
^^So how do you change the .xml in order to change the display order and items displayed?
Old Mar 12, 2007 | 08:12 PM
  #159
MalibuJack's Avatar
Just open the data.xml file in evoscan, or the requestid.xml file in mitsulogger and change the order, the first one in line gets the first available column (after the date/timestamp) and so on.
mitsulogger doesn't include headers or commas for unused fields so its really not as much of an issue with it, but some people do like to reorder the fields based on relevence or how they want their data grouped.
Oh and a quick blurb about Mitsulogger 1.6, I have AEM wideband support working, and should have Innovate support by the end of this weekend. Hoping to get a release out on sunday night.
Old Mar 13, 2007 | 05:32 AM
  #160
^Thanks. I did a search and found the file. Now I have to read up on .xml code before making any changes.
Old Mar 13, 2007 | 09:15 AM
  #161
Mr. Evo IX's Avatar
So, can I calc IDC in Evoscan and have it appear on all my logs?
Like this?
<DataListItem DataLog="Y" Display="Injector Duty" LogReference="IDC" RequestID="00" Eval="([InjPulseWidth]*[RPM])/1200" Unit="%" MetricEval="" MetricUnit=""
ResponseBytes="1" GaugeMin="0" GaugeMax="125" ChartMin="0" ChartMax="125" Notes="([InjPulseWidth]*[RPM])/1200"/>
Old Mar 14, 2007 | 07:57 AM
  #162
Mr. Evo IX's Avatar
Ok, this worked in Evo Scan and it creates a log column for IDC and calculates it. Neat.
Next I put the items in the order I wanted to see them, well I ran into trouble there because LoadCalc and IDC need to be after the items that are referenced in their calculations, not a problem.. I moved them.
Ok going well, so now I think it would be cool to see IDC in DataLogLab and that's where I ran into problems. Although I was able to change the evoscan.txt file to include a definition for IDC, DataLogLab will not accept the new data item and I dont know how to get it in so I just removed it from the Evoscan.txt file for now.
I have a new problem.. I've done something to make Dataloglab not plot my wideband?? I put the original DataLogLab evoscan.txt file in and still no go. Does it have something to do with the order? All of the other columns plot fine and other the fact that they have an IDC column and some of the item's order is changed nothing is different in the evoscan logs. Can someone please help me out here. Thanks!
This thread has logs
https://www.evolutionm.net/forums/sh...d.php?t=257452
Old Mar 14, 2007 | 12:35 PM
  #163
tcarretti's Avatar
I have a question that I haven't been able to find an answer to yet.
I recently had a bunch of new parts installed including some Denso 720cc injectors. I sent my ROM to AMS to have Chris scale the values for the injectors roughly so that I would be able to drive the car until the tuning date at the end of the month.
If I log with either Mitsulogger or Evoscan, will I get accurate readings or is there something that has to be changed in the software to reflect the changes that wree made to my rom for the injectors in EcuFlash?
Sorry if this has been asked before, but I've been searching for over an hour with no luck.
Thanks,
Tony
Old Mar 14, 2007 | 12:48 PM
  #164
MalibuJack's Avatar
Yes, you need to set the Injector scale and Voltage latency values in mitsulogger, you would get those values from your ECU's rom using ECUFlash.
I am also in the process of getting the load calculation even more accurate by interpolating the 11v and 14v injector latency values.
Old Mar 14, 2007 | 01:53 PM
  #165
tcarretti's Avatar
Thank you! Will do...
Tony
Quick Reply: ECUFlash / Evoscan / Mitsulogger Questions
