ECUFlash / Evoscan / Mitsulogger Questions
#1681
TO Conclude:
I ordered a Tactrix 2.0 after exchanging a couple emails back and forth with their support. They told me that they didn't have a live logging option, but theirs would log via microSD and could view it later.
Well i figured that would suffice if EvoScan never ended up working properly.
I received it today and it instantly works with EvoScan. If you get the error like i did above with the 1.3U cable, order a 2.0 from tactrix and EvoScan should come to life. I'm going to see if it can dual log later today. Would be nice to jam a high GB card in there and log every drive ever.
#1682
starter kit
So I have an Evo 9. I need a starter kit or something for this car, tactrix cable and whatever I need to start logging/tunning. Sorry I know this is a total noob post, but i really need to cut to the chase. thanks in advance!
#1683
Cant read rom
Hey Guys, (ECUFLASH WONT READ) yes i've read other questions..
My Evo 8 has been previously tuned by IS motor racing from the previous owner.
I have been trying to read the ROM however i continually get an error message saying check log for details.
The strange thing is i was able to read the ROM on my mac using the 1.38 software, however that's as far as i could go as it couldn't find the correct definition assuming i need a Tephra mod definition for a Evo 8 MR JDM. It just seems strange that i cant get that far with the current 1.42 software.
I'm using the 1.3u cable, and have tried it with various laptops, and parallels on mac.
#1684
i had this issue earlier this year and it ended up to be the order in which I installed everything. To fix I had to uninstall everything and start installing them in a specific order. I do not remember that order....
if if all else fails buy the 2.0 cable from tactrix... it fixed all my issues
Kieran Fercher (Jan 13, 2017)
#1685
I would suggest trying a windows version with the 1.3u cable. Non-parralels.
#1687
#1688
I think that since the 1.3U protocol is so old it's not working properly with faster USB Speeds, or on the flips side, there's a huge batch of bad cables that the MFR just let out.
Stay tuned.
#1689
will the innovate lc-2 wideband kit log in evoscan or do i need an lc-1??
also can somebody tell me if this rom is a tephra v5.10 or a v7?
http://imgur.com/a/uUb7k
#1691
so im pretty new to this but i think i have some basic things down
i have a usdm 2003 evo with a rom id of 94170008 and i understand using a different rom id for better tuning capabilities but im confused on how to get the ecuflash to read a different rom id
i have done tons of searching here and elsewhere and it hasnt answered any of my questions
#1692
#1693
<rom>
<romid>
<xmlid>94170715</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>94170715</internalidhex>
<make>Mitsubishi</make>
<market>TDM</market>
<model>Lancer</model>
<submodel>Evolution VIII</submodel>
<transmission>6MT</transmission>
<year>2005</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
i dont know if thats the right way to do it but i opened it up in ecuflash and it didnt give me an error by some of the values are kinda messed up
i read that i have to switch my maps over but i dont know how to do that, i understand how to switch the timing and fuel but nothing else
thanks again in advanced all this researching is getting kind frustrating not finding what i need
#1694
Hey guys,
I recently bought a Tactrix 2.0 cable, and am trying to first off simply download my ECU rom from an Evo 8 MR, but EcuFlash doesn't seem to connect (mac) and shows the "No vehicle interface" message.
Does anyone have any tips/ guidance on how to start doing this? Everyone seems to say it's as simple as connecting the cable and then going to ECUFlash, but failing that hurdle, am a bit lost...
Thanks!
Thanks!
#1695
hello friends, just seeing if any of you have had this issue and if so how did you remedy it?
background on this:
car is hitting the traps at about 8300 rpms and running 10.30's at about 140mph
in every log i have the rpm maxes out at 7968.75 and just stays there. it makes it really difficult to adjust the top end of the timing and fuel maps.
i did submit a support ticket to hamish. I was just hoping to get an answer quick, thought maybe it was a dumb issue I just wasn't seeing.
out the box the settings for rpm request id 21 the scaling is .01 and the min/max chart is 0 and 8 respectively and 0 and 80 for gauge.
I tried to adjust it to 0 and 11 and 0 and 110 respectively thinking that should give me 3000 rpm more resolution to see but I guess I was wrong. I guess i am stumped on this. I am sure it is something really dumb and easy to fix just cant see it
If you take formula and solve for x 7968.75=255 so I assume the request is we are logging is a
0-255. I tried using 2 byte rpm mut request but that doesn't work.
Any body have any insight into this?
background on this:
