ECUFlash / Evoscan / Mitsulogger Questions
#256
I got the IDC% calculation to work using the RequestID that the 2-byte RPM mod references. I'm not sure if it really matters, but I got it to work either way.
Code:
<DataListItem DataLog="Y" Color="" Display="Injector Duty Cycle" LogReference="IDC%" RequestID="02" Eval="([InjPulseWidth]*[RPM])/1200" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" Notes="([InjPulseWidth]*[RPM])/1200"/>
#258
missing info in "connect to ecu"?
(problem fixed,pathway changed on its own I just changed it back to the way it was)....I installed a jdm map sensor and 720 fuel injectors along w/ the corrections to the
rom and injector size and latencies.Uploaded it to the ecu and now when I try to
connect to the car's ecu the small screen pops up to choose the car your trying to
read from and nothing is in the box.Anyone have any idea what happened and
how to fix?....thanks
#259
Hey guys i'm trying to figure out how close to accurate is the road dyno graph? To what dyno does it compare to. And what are the differences between the ratios of an evo 8 5spd to an evo 9 5spd. The main reason I am asking is because we did a dyno log and we didnt change that setting. I had made 318hp and 312tq torque but that was under the specs of an evo 8. I have the 9. i also had 4 people in the car to include myself which totaled 630lbs and a half a tank of gas.
Any info is appreciated.
just thought i share my experience with the evoscan dyno feature
#266
Code:
So i tried copy and pasting this into my evoscan/data settings and I keep getting an error saying:
"CANNOT CREATE DATA.XML FILE ETC. ETC.
MAKE SURE PATH AND FILE NAME ARE CORRECT"
I opened it up using notepad and wordpad also, same thing happens each time.
I'm using vista..
tia, jamie
#270
I'm using vista..
tia, jamie
I'm using vista..
tia, jamie
If you are still having trouble, PM me and I'll send you my e-mail address. You can send your data.xml file to me and I'll add it for you.
