ECUFlash / Evoscan / Mitsulogger Questions
Old Feb 10, 2008 | 02:20 PM
  #346
taavisev's Avatar
when i open the log there is no changes just same numbers!
Old Feb 10, 2008 | 02:24 PM
  #347
taavisev's Avatar
here is the log
Old Feb 10, 2008 | 03:20 PM
  #348
DrivinMissDaisy's Avatar
Originally Posted by taavisev
here is the log
Ya I would say you have a problem. No clue on what it is.
Old Feb 11, 2008 | 03:08 AM
  #349
taavisev's Avatar
problem solved!
there was baud rate 19200 i dont know how it gets there but it all good now!
there must be 15625
thank u DrivinMissDaisy! for thinking:P
Old Feb 13, 2008 | 11:25 PM
  #350
JoizeeX's Avatar
a stupid question:
is there a difference between the 2 cables sold here? http://www.limitless.co.nz/cables/
i want to use Evoscan and maybe at some point ECUflash. also, i want my friend to try Evoscan on his WRX. i'm just not sure from the descriptions. it sounds like they do the same thing?
thanks guys
Old Feb 15, 2008 | 06:11 PM
  #351
andrewzaragoza's Avatar
^ i believe the second one will only allow u to log. it will not allow u to read and reflash your ecu. Please correct me if im wrong.
Old Feb 16, 2008 | 11:57 PM
  #352
JoizeeX's Avatar
thanks Andrew.
anyone else wants to chime in?
Old Feb 17, 2008 | 07:21 PM
  #353
EVO8emUp's Avatar
Old Feb 18, 2008 | 03:44 PM
  #354
Inprogress's Avatar
MalibuJack,
For whatever reason I can't download Mitsulogger v1.6 Beta 3 from aktive matrix. I am running XP via bootcamp on my macbook pro and evoscan/ecuflash work fine. I have no idea why I can't download mitsulogger. The download prompt opens, I say to save the file and it doesn't download anything but an empty icon on my desktop that's like 312kb.
Any ideas?
Old Feb 18, 2008 | 06:19 PM
  #355
20Grockit's Avatar
one cable is for logging, the other is for logging and flashing.
Old Feb 18, 2008 | 06:21 PM
  #356
20Grockit's Avatar
im a newbie to tuning my car myself so i could use some help. the first tune with ecuflash/evo scan is gonna be done by my buddy at his shop. he has a dynojet and wideband. after he tunes it for me im gonna tune it myself after i do some more mods. i still have to throw in a couple more things to have my setup maxed out for the time being. when i go to do a log what exactly do i do. i know i need to do a pull in third gear but do i just open up evo scan?
Old Feb 18, 2008 | 07:48 PM
  #357
MalibuJack's Avatar
Originally Posted by Inprogress
MalibuJack,
Any ideas?
Its probably browser related... But try renaming the file (or saving as) a filename MITSULOGGER.RAR a rar file is a compressed file like a zip so you'll need winrar from www.rarlabs.com
Old Feb 18, 2008 | 07:55 PM
  #358
Inprogress's Avatar
MalibuJack my man, you are a badass.
Can the variables be moved closer to one another? Also, how do I incorporate 2byte load and JDM map in mitsulogger?
Thank you!
Old Feb 18, 2008 | 08:08 PM
  #359
MalibuJack's Avatar
You can change the order of the items in the XML file, keep in mind if any of the formulas use other requestID's, you'd want to order them so they occur before the formulas that use them, this will give you the most current data for your calculations.
Old Feb 19, 2008 | 12:25 PM
  #360
scc_tuner's Avatar
Hey MAlibu,
Do you have any experience with 2003 3g eclipse 2.4l manual trans. i have ecuflash and evoscan and they both work with my ecu, but when i read my rom i can't view my maps due to my immobilizer keeping the ecu locked. is there a fix for this without paying flashbluers on club3g or is everyone keeping it secret so he can corner the market!!??????
Quick Reply: ECUFlash / Evoscan / Mitsulogger Questions
