ECUFlash / Evoscan / Mitsulogger Questions
Old Jun 13, 2009 | 01:33 PM
  #601
alatza28's Avatar
Originally Posted by JackM
Hello all, we are having a problem with this:
ending init sequence 1 (0001)
sending init sequence 1 (0003)
sending init sequence 1 (FFFF)
no response to any known code
So I tried (Just in case) with the unlocker running
sending init sequence 1 (0001)
sending init sequence 1 (F0F0)
I know this has been asked before and we tried keeping the car running, the unlocker, and the 1.41 of ECUflash. We are using the tatrix 2.0 cable and nothing seems to be working with ECUflash.
EVOscan seems to work fine with no issues, so we know the cable, USB port, all hardware can see the ECU okay, we believe it to be a software issue with ECUflash...
Any ideas? Thanks!
Jack
Hello all.
If exists somebody which can answer in this question why this tired many people.
Thank you very much and we wait the answer..
Old Jun 13, 2009 | 02:47 PM
  #602
vmrevo9's Avatar
have you tried uninstalling ecuflash and reinstalling it? if not try a different version.
Old Jun 18, 2009 | 02:31 PM
  #603
03lances's Avatar
Deleted...
Old Jun 26, 2009 | 07:17 AM
  #604
poombah's Avatar
having exact same issue on Evo4 with Evo7 Ecu
only suggestion on OpenECU forum was to ensure pin 79 was bridged to the second plug on the tactrix 2.0 cable.
Old Jun 26, 2009 | 06:31 PM
  #605
Evoryder's Avatar
New mitsu logger still doesn't see past 25.5 psi for zeitronix
Old Jun 29, 2009 | 08:53 PM
  #606
downshift411's Avatar
question about evoscan or mitsulogger, which one out of the two can use data logging for emissions...well i need readings for no2, o2 being too high. something to prevent me from failing emissions the first time. i also what to know if any of these two softwares allow me to check the obd2 monitor readiness.
Old Jul 2, 2009 | 09:30 PM
  #607
^^^bump
Old Jul 2, 2009 | 10:07 PM
  #608
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
None, you would need smoke probe in your exhaust that is capable of NOx detection and no car that I know of is having such sensor.
Old Jul 4, 2009 | 03:08 PM
  #609
D-VO's Avatar
Hey acumus. I've got a question involving the fuel trims. I've tried disabling the immobilizer using the periphery bits, but I'm still reading 0.1008. Is there anything else I'm missing? I've been searching for a couple of hours and came up with nothing, any help would be greatly appreciated.
Old Jul 7, 2009 | 03:37 AM
  #610
acamus's Avatar
0.1008 is 0 - improper scaling in EvoScan.
for MUT_C,MUT_D,MUT_E
most accurate is here or written differently here
Old Jul 7, 2009 | 10:36 AM
  #611
iggy2009's Avatar
Can someone please advise me. I have JDM Evo8, Rom ID is 93660005. I am using Ecuflash to download my rom info, it opens without any problems, but when I am trying to save ROM it gives me this error: "There was an error writing this ROM file. See the message log for details." [/I] [21:27:49.625] can't open image file for writing. Any idea why this happens ?
Another thing is I cannot open ROM files, it says There was an error reading this ROM file. See the message log for details, [23:26:41.953] can't open image file.
P.S. This car has been flashed before, unfortunately I dont know what software was used
Old Jul 7, 2009 | 02:07 PM
  #612
iggy2009's Avatar
Now it's working fine, dont understand why
Old Jul 10, 2009 | 09:21 AM
  #613
Go_Lancer_Go's Avatar
cannot find a solution to this error, using a netbook with WINXP..
Info: Initialize Vehicle ECU...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: Waiting for INIT Response...
Info: ECU ID:
Info: Connection successful...
Error: Object reference not set to an instance of an object.
Info: Datalogger Ended.
Old Jul 13, 2009 | 02:47 AM
  #614
MR. EVO MR's Avatar
what about logging ebc like mine aem tru-boost, with evoscan?
Old Jul 13, 2009 | 10:30 AM
  #615
termite_one's Avatar
I would like to run Evoscan on a Macbook pro using windows parallels. Has anyone done this? I am sure its been answered before, but I cant find it in search.
Quick Reply: ECUFlash / Evoscan / Mitsulogger Questions
