ECUFlash / Evoscan / Mitsulogger Questions
#616
Ok so I have heard different opinions on whether you can log your WB with mitsulogger some say ya some say no. Which is it? and what do you guys recommend for a WB that will work good with this?
#620
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
http://evoecu.logic.net/wiki/MUT_Requests
That means 30
That means 30
#621
That means 30
That means 30
#622
Anyone can tell me what is happening here?
"[21:27:43.552] Using interface OpenPort 1.3 Mitsubishi TX14qcCDccfaf4c900000000000000000000000000000000
[21:27:43.553] interface close
[21:27:43.560] unable to connect to vehicle interface."
I can't seem to read my ROM!
I am on a 32-bit Vista OP by the way.. drivers checking out okay.. redid a full install same thing. Question cnt seem to choose my port on ECU 1.42.. also seen a under HELP there is Licensing.. what is that for.. TIA
#623
anyone know how to get the jdm map senser to work on the evo9?? a few of my buddies that i cant get a hold of right now have the evo 10 senser in the evo 9 so that evoscan allows it to read boost or something like that?? anyone have any clue
#624
#625
BUMPING for help
anyone can tell me what is happening here?
"[21:27:43.552] using interface openport 1.3 mitsubishi tx14qccdccfaf4c900000000000000000000000000000000
i can't seem to read my rom!
I am on a 32-bit vista op by the way.. Drivers checking out okay.. Redid a full install same thing. Question cnt seem to choose my port on ecu 1.42.. Also seen a under help there is licensing.. What is that for.. Tia
#626
little pop up values box displays different data when positioned on the same time line but different data line!
how can this be?
i.e @ 10secs pointing at rpm line the little box says rpm 5000 and wideband 11.0 which is great but then point to wideband line at 10secs and it shows 11.0 but 1176 rpm!
plus only pointing at wideband the little box has all 3 time stamps but the others only have 2!
how can this be?
#627
i did my search and also tried everything i could. No good.. SiC said its a EDM rom but still wont open. I downloaded the 53040007 def. but for some reason it just wont go thru...
Need a definition to read this on ecu flash. Please help guys!
Click here to Download
thanks!
thanks!
#628
When use EvoScan with V6 engine, do I need to customize change the formulas for those injector related functions? Eg, IPW, IDC, Fuel Consumption, LoadCalc, etc? As I know those functions/formulas were verified by Evo with 4 cyclinders, how about 6 cyclinders engine? Are they using the same functions/constants?
Thanks
Thanks
#630
any idea why mitsulogger wont work on my hp laptop.. but works on everybody elses.. it has vista, but so does my buddys and works just fine on his.. everytime i double click on it, a windows screen pops up and says mitsulogger has stopped working, windows is looking for a fix to this problem.. i have tryed downloading it multiple times and just wont work. please help me out guys
