ECUFlash / Evoscan / Mitsulogger Questions
#691
I connected logworks to see if that gave me a good reading...and it does. So that means its not my Lc-1 its a software issue with evoscan... Any ideas? I feel like Ive seen some other people with this same problem. I just cant find the solution.
-Ethan
#694
When im logging in Evo Scan I only have 11 differnt sensors being logged. But I still get very few data logs per cycle.. does that make sense? Meaning my resolution is very very small. A full third gear pull is only giving me like 10 lines of data.
Whats the deal here? Ive never had an issue like this with mitsulogger
-ethan
-ethan
#696
Well its not a netbook. Its only about 2 months old. Toshiba Core2 with vpro i think its a 2.8ghz. dual core obviously and 3gb of ram yada yada. Its DEFINITELY not a computer limitation.
#697
Hey. My problem is that my Ecuflash doesn't reacting for .xml files changing. All the time I have the same tables, even when I copy modified xml's (for example tephra v5.1).
This is happening only on my new laptop with Vista Home Basic. On old laptop with Win XP everything is ok. Ecuflash 1.42.2595
Any ideas ?
Any ideas ?
#698
-ethan
-ethan
Any ideas guys? Im logging with a laptop that is about 3 months old. Toshiba core 2, 2.8Ghz with 3Gb of ram.
Ive attached them below
-Ethan
#699
Any ideas ?
Any ideas ?
I too am using Vista and EcuFlash 1.42.2595.
Any help would be appreciated.
#701
Hey all, newb here...
I recently installed cams, had a new map flashed to my ECU. Tuner wants me to log a 3rd gear pull until redline logging everything!!!! Problem is, I try but logger can't seem or want to log passed 3.5K rpms.
I recently purchased/downloaded evoscan and flashed the new map and have not made any adjustments or anything to any settings of Evoscan. A few days ago, I did log some low rpm pulls with no problems.
I have the tactrix 1.3 cable and it connects with no problems. I am just affraid to tear a hole in the block, I do see knock as the ses flashes and causes me to worry some....
Can anyone help me out figuring what might be casuing this? I need to log as I need to adjust the map some more!!!!
I have no clue as I am no tuner and have no tuning experience!!!
HELP PLEASE!!!
HELP PLEASE!!!
#702
Map Tracer & 1byte Load problem
Don't know if this has been asked before, sorry if it has.
Im using Tephra v7 and logging 1 byte load in EvoScan 2.6. Now...when i finish the log and i open the log file in a graph mode i can see the 1 byte load logged...sweet . Now when I go into Analyse - csv log- Map tracer and open up the same log i cant/don't see anything when im trying to reference the 1 byte load... tried selecting it from the dropdown menu, it there but brings up nothing - blank, wierd. its there in the graph mode so the info is there but nothing when i try maptracer...
anyone??
anyone??
#704
Any ideas ?
Any ideas ?
#705
Tried a search and to my luck I can't find anything, but I was wondering what the difference is for the Limitless 1.3U and 1.3R cables, I see that they're the same exact cable, and 1.3U comes with the serial license. But I also see that ecuflash is free to download, so the serial license doesn't make sense to me.
Should I look into the 1.3R? Basically I'm just planning on doing some data logging, as well as disabling the P0300 test, and forcing the OBD inspection pass. Please excuse the noobish post, I've been out of the game for quite a while. Thanks guys!
