ECUFlash / Evoscan / Mitsulogger Questions
Old Aug 18, 2010 | 04:41 PM
  #811
Rex915's Avatar
I just got a tactrix 1.3 and I downloaded the ecuflash from tactrix, but it wont read my ecu.......I opened ecuflash, then turned my key switch to on, plugged in the tactrix usb, and then selected read on ecuflash. I choose my car from the list but it wont read it,"no documents"??? Does anyone know why its doing this?? I uninstalled and reinstlled ecuflash but that didnt fix it. Thanx for looking
Old Aug 18, 2010 | 04:56 PM
  #812
metalsaber's Avatar
Which version cable? If you didn't get a 1.3U cable you can't from your ECU.
Old Aug 18, 2010 | 04:59 PM
  #813
Rex915's Avatar
how can you tell what version it is?
Old Aug 18, 2010 | 05:06 PM
  #814
metalsaber's Avatar
Where did you buy it?
Old Aug 18, 2010 | 05:11 PM
  #815
Rex915's Avatar
I bought it on here, I went back to the original for sale thread where I bought it and it does say 1.3u
Old Aug 18, 2010 | 05:40 PM
  #816
Rex915's Avatar
It does say I am using the tactrix universal 1.3U but the last two codes say interface close and unable to connect
This is what I get after I select my evo:
[18:37:45.389] EcuFlash Version 1.42.2595
[18:37:45.389] OS Version Windows Vista
[18:37:45.389] Qt Version 4.5.0
[18:37:45.389] 56 memory models read.
[18:37:45.389] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[18:37:50.334] 343 ROM metadata models scanned.
[18:37:50.334] checksum module "subarudbw" loaded.
[18:37:50.334] checksum module "mitsucan" loaded.
[18:37:50.334] flashing tool "wrx02" loaded.
[18:37:50.334] flashing tool "wrx04" loaded.
[18:37:50.334] flashing tool "sti04" loaded.
[18:37:50.350] flashing tool "sti05" loaded.
[18:37:50.350] flashing tool "mitsukernel" loaded.
[18:37:50.350] flashing tool "mitsukernelocp" loaded.
[18:37:50.350] flashing tool "mitsubootloader" loaded.
[18:37:50.350] flashing tool "shbootmode" loaded.
[18:37:50.459] flashing tool "shaudmode" loaded.
[18:37:50.459] flashing tool "subarucan" loaded.
[18:37:50.459] flashing tool "mitsucan" loaded.
[18:37:58.134] Using interface OpenPort 1.3 Universal TX2BMxCf1beba5c5efecb35ffd0bdc8a06691e97d1e35d0d
[18:37:58.134] interface close
[18:37:58.134] unable to connect to vehicle interface.
Old Aug 19, 2010 | 01:10 PM
  #817
mullen's Avatar
wierd problom with evoscan, it wont display the dtc but i can clear them...says it timed out and to restart the car which i have done
Old Aug 19, 2010 | 05:33 PM
  #818
AlwaysinBoost's Avatar
Help
here is the error I'm getting when I try to connect to EVOScan:
Old Aug 22, 2010 | 07:57 AM
  #819
mullen's Avatar
i spent about 4 hours reading lastnight and must have had 10 windows open reading on tephra and speed density but still could not firgure out how to load my xml pack and 94171715 into my ecuflash....maybe im just stupid but could someone give me a hand, im going to continue to read
thanks a ton
Old Aug 31, 2010 | 10:32 AM
  #820
motocooney's Avatar
Scantech
Could someone please email me or PM a download of the Scantech software?
The aktivematrix is not working..."upgrading the site" so I can't register and download Scantech.
Thanks so much!!!
email is motocooney@yahoo.com
Old Sep 1, 2010 | 05:33 PM
  #821
EvolutionVIIIrs's Avatar
so ive loaded the ecuflash software, have a tactrix 1.3 cable. I can read my rom fine, but for some reason i still cant get any parameters of the log. When the window popped up and asked for an internal id, i just picked one for an evo 8.
heres what rom info i have.
my evo is march 04 btw..
ROM info
make-mitsubishi
model- lancer
submodel-evo8
market-usdm
trans-manual
year-2004
ecu id - (blank)
case id- MN132874
internal id-96530706
flash method-mitsukernel
memory model-sh7052
checksum module-(blank)
any ideas? im trying to load the temp map for speed density..
i cant even edit my own info!
thanks for the help
Old Sep 1, 2010 | 07:16 PM
  #822
metalsaber's Avatar
I thought you had to do speed density through Tephra?
Old Sep 1, 2010 | 07:33 PM
  #823
ROM info
make-mitsubishi
model- lancer
submodel-evo8
market-usdm
trans-manual
year-2004
ecu id - (blank)
case id- MN132874
memory model-sh7052
thanks for the help
you do. But im still trying to be able to access my ecu completely. I had the car tuned, and when i plugged in with ecuflash i had to choose a Rom ID. I wasnt sure which one to pick, so i picked the first 04 USDM Evo 8 rom id. ever since that point all i can do is see the rom info. No parameters come up for me to tune. Id like to get fully into my ecu, Ive checked the definitions files on ecuflash and the file isnt there for the Rom id i picked. But like i said, i just randomly picked the first USDM evo 8 rom in the begining. This was after the tune. SO everytime i try to reset the rom id, i have something i can go back to.
Once this is all figured out, ill be loading tephra so i can edit the map for SD.
Old Sep 1, 2010 | 07:51 PM
  #824
wizzo 8's Avatar
Subscribed
Old Sep 3, 2010 | 06:44 PM
  #825
turbooutlaw1976's Avatar
Did anyone ever find such a list?
Originally Posted by EvoAnthony
We need an index for what all the boxes mean on the left hand side of the ECUFlash software....
Can you help Jack?
Quick Reply: ECUFlash / Evoscan / Mitsulogger Questions
