ECUFlash / Evoscan / Mitsulogger Questions
#1366
if you have the 1.3U then that means you still have pin9. you will need to have that removed. not sure if you just ordered it or bought it off someone else but if just ordered they might swap it out for you if you mail it back to them.
#1367
Trouble with Evoscan
Hello. I'm having some trouble with getting an accurate value on boost and knocksum is not logging at (as if it isn't turn on or the sensor isn't there). For boost, at idle, it reading 20 psi. During WOT, it went as high as 40ish. I do have a boost gauge and Greddy profec b spec 2. The profec is set at 19psi and the boost gauge shows same. Searching, I'm assuming my eval equation got screwed up even though I didn't touch it?? For Knocksum, it just blank..kind of like the External WB and it isn't connected. What am I doing wrong??
#1368
After researching, it seems people with a 3 bar + sensor has escrew boost readings because the formula is incorrect. Does this sound about right? I'm not sure if I have one or not (bought car used with mods)
#1369
I am having boost logging issues as well, but I think mine might be a little simpler. I downloaded the latest evoscan V2.9, and used the same formula that I used previously on V2.7 which worked perfectly, however, I have been getting this error, anyone know what I am doing wrong? I am using an OMNI sensor on stock ecu. Thx in advance.
#1370
Never mind
After hours of search and looking over my engine bay, I realized I do have a stock 05 USDM Map sensor. From what I'm reading, the stock MAP sensor doesn't read over 2 psi and evoscan have crazy readings. So, I need to get a JDM Map sensor?
#1371
I am having intermittent issues connecting my ECU to Evoscan. It works about half of the time just fine and logs completely. Other times it doesn't try to connect and when I prompt it to start datalogging, it states that I need to try connecting the 2.0 cable. I have the 1.3 and it is set to 1.3. Again, it works perfectly about half of the time. Any ideas?
#1372
#1373
Exactly! ^ I keep thinking I've figured out a temporary fix (restarting the program, rebooting the entire computer, reseating the cable etc.) but it jut comes down to sheer dumb luck and the car basically tells me when it wants to be logged lol
pic of whats happening:
#1374
Thx
#1377
is there anywhere else to get evoscan from? i keep trying to get it from the evoscan website and its not working. ive tried multiple times and everytime i go to my cart and click checkout it then tells me that my cart is empty? any help would be great or should i just say screw it and get mitsulogger?
#1378
#1379
#1380
Hi , Does the Evo scan and mitsu logger support NGK AFX wideband and ECM AFM 1000/1500 with DIS1000 ?
http://www.aptuning.net/NGK_AFX_Wide...20wideband.htm
