Obd2
Obd2
for those people who have tuned the ecu, what is the "biggest " cam you think you can get to pass OBD2 emission test?
I can get the afr's spot on with an aftermarket ems even with revolvers, but that is a moot point with emissons tests. Prolly can't make the other gases test though.
OBD-II test doesnt use a sniffer so it doesnt matter..
However, if you need to do a sniffer test, then reducing cam overlap, running the car in closed loop, and playing with the timing a bit to reduce Nox emissions will pass a sniffer, and having a catalytic converter..
Sniffer tests are not too tough. I once easily passed a sniffer on my OBD1 Turbo miata running phased injection & no cat.
For "offroad" use, it would be great to disable the codes associated with the secondary O2 in ECUFlash.
Thats likely coming soon enough.. It seems that the development has been focused on the 2 byte load and disassembly recently.
I'm hoping that I can redirect some focus on enabling/disabling/altering some CEL Code trigger settings and test parameters so things like aftermarket intake manifolds that don't have EGR provision, or running an aftermarket MAP sensor, won't throw a CEL code or cause the supported tests not to complete.
Friends in low places :P
Yes, this works well for me. But, if the code could bypass the rear O2, then we could use the signal for logging other data (such as boost) as suggested in a separate thread.
marylandevo8
32
Apr 7, 2013 09:13 AM
mx597turbo
Nov 25, 2011 10:46 AM
