What parameters do you log and why?
Old Feb 2, 2007 | 07:15 PM
  #31
nj1266's Avatar
Originally Posted by l2r99gst
To my knowledge, there is no sensor calibration needed. The important thing when using a map sensor is to make sure where your connection for 5V and ground is taken, so that your readings are accurate for reference to the sensor.
I'm going off of memory here, but I believe the SSi-4 takes into account any changes in grounding if the external sensor is hooked up properly.
Eric
What I am asking is what is you min/max volts=psi set to in Logworks? Why did you set them the way you set them.
I have mine set to:
0v = -14.7 psi
1.6v = 0psi
5.0v = 31.1 psi
This is based on the info that I got from the links posted above.
Old Feb 3, 2007 | 06:58 AM
  #32
l2r99gst's Avatar
I have mine set to:
0v = -14.7 psi
1.6v = 0psi
5.0v = 31.1 psi
Oh, I see. I misunderstood your question. You are asking about the configuration or set-up of the sensor.
The sensor that I use, the GM3.3 bar (not the GM 3 bar), has a linear response with respect to voltage. The pictures I posted a few threads up show that relationship. So, since I use the SSI-4 and LogWorks, it gives you the ability to enter two voltages and their respective pressure readings and then expand that to 0...5V.
The 3.3 bar sensor, from the datasheet posted, has the following properties for 4.5V and .25V:
4.5V=48.298 psi absolute = 333kpa
.25V=7.252 psi absolute = 50 kpa
So, I could simply enter those two data points and LogWorks will extrapolate out.
Since I like crunching the numbers, myself, I simply found the slope from the two points, and then found the equation, then applied to psig for actual boost pressure:
m=41.046/4.25=9.658
y=9.658x+4.8375
or boost pressure (-14.7 psi)
y=9.658x - 9.8625
.25V = -7.448 psi
4.5V = 33.598
or
0V = -9.863 psi
5V = 38.4275
Eric
Old Feb 3, 2007 | 07:21 AM
  #33
alan678's Avatar
Originally Posted by voidhawk
it depends on why you are logging - for a health check it'll be mainly knock sum, IDC (making sure the injectors aren't maxed out), and maybe AFR if you have a wideband. For tuning it'll be lots more to get a more complete picture of what's going on and where to tweak.
On EvoScan, how do you get the IDC number and what do they mean (like what are the lowest numbers and the highest numbers)....
Chet3215
Jul 24, 2016 12:51 PM
ridenrunwv
Sep 29, 2015 10:59 AM
RedLanEVO
Jun 8, 2008 12:20 PM
racer135
May 17, 2008 03:00 AM
badhabit90
25
Nov 13, 2004 10:56 PM
Quick Reply: What parameters do you log and why?
