A:F 0.5 leaner when it's colder outside
I mentioned this in passing.. But you guys need to check
1) Barometric Pressure Compensation Table
2) Air Temperature Compensation Table
As mentioned earlier, Air Density / Air Mass is calculated by the ECU, and my guess is one of those two tables needs tweaking now that the engine's VE has been altered.
Were on it Boss
OK, I did a log at lunch air temp log is 60F - 68F.
A:F 11.7 from 5000rpm to 6500rpm
50 45u
77 41u
82 34u
I changed my air temp comp to the following:
50 41u
77 41u
82 41u
At same temps (60F - 68F) A:F dropped to 11.4 to where I like 'em
I assume tomarrow at 80F instead of 11.1, I'll perhaps be at 11.3, well see
I will tailor to climate later more sensibly later
50 45u
77 41u
82 34u
50 41u
77 41u
82 41u
Probably, but perhaps also used in conjunction with a change in altitude
It sure would be nice to have the chief engineer's logbook (in english) at Mitsu written 4 years ago
Here is how not only the effects of temp have on air volume but also how temp comp may play an indirect role by leaning at lower temps.
A WOT log this afternoon at higher temps with 41units will only confirm this
C6C6CH3vo: You mention a change in altitude.
This is a good point. It isn't the general density of free air that matters for combustion, but the partial pressure of O2. In barometric pressure, 1000' of altitude change equates to about 1" of pressure up to almost the troposphere, but O2 follows a different, less linear curve.
-jjf
I'm almost 78% certain the chart is mislabled as "celcius" and that the temp value corresponds to MAF temp in F. Also I am seeing real changes in WB from input in those areas - for now I will have to trust that it was just an overlooked mistake
-32 degrees Centigrate would be -57 degrees F an 84 degrees C would be 183F. I don't think intake temps reach those extreems.
Another thing they did was use the word Celcius for C, C is Centigrate and always has been. Celcius was an opium fiend and his name took credit for the unit of measure by mistake and still does today.
Anyhow, air temps reached 90 degrees today and my A:F has changed very little compared to last nights 60F log. However, there was nowhere near the power, but at least a little more than if A:F dipped into the 10's
Ooops Sorry
Dyslexia. I'm alreight until negative values, but that stuff about Celcius is mostly true, I can assure.
(C*9/5)+32 = F
(F*5/9)-32 = C
My question now is wether or not that table supposed to be C (Centegrate) of F. If C then what in the world is it measuring?
(C*9/5)+32 = F
(F*5/9)-32 = C
Personally, I'm betting it is indeed Celsius/Centigrade, not F. Of course the upper two values are very high, but if they were in F, they'd not really be high enough IMO. Also, keep in mind that this isn't ambient temp the ECU is measuring, it's intake air temp. It is very feasible (and likely) for the underhood intake temp to get into the mid 100's (F).
Also, I work at a Japanese company. Trust me, they don't know F. They don't work in F. I hate to stereotype, but there's no way a Japanese-made ECU has anything F in it.
I'm excited to see that you saw a difference by tweaking the values. I'd like my AFR to stay more stable with our wide-ranging MI weather. (and I'm very jealous about your 85F comments as I sit here in northern Ontario doing cold-weather vehicle testing!!)
Ooops Sorry
(C*9/5)+32 = F
(F*5/9)-32 = C
(C*9/5)+32 = F
(F*5/9)-32 = C
(F - 32) * 5/9 = C
I'm doing this everyday mentally because I am STILL not used to use somebodies armpit as temperature reference
According to legend, when Mr. Farenheit invented his thermometer, it was a cold winter. He put it outside and read it early in the morning. He thought it cannot possibly get colder than that. So he marked it there with 0. He then went inside, looking for a higher temperature reference. From working outside he developed a slight fever. He stuck the thermometer under his armpit to see if it reacted. It did nicely so he marked that temperature as 100. That's how the Farenheit scale got invented.
Regards,
Klaus
