349whp mustang dyno EcuFlash Map
I find it interesting that your timing near onset of boost is about what mine is on 93 with the better cooling passages and MIVEC. You ramp up the timing alot faster than I can without the aforementioned "grumpiness" though. My car on pump doesnt seem to like much more than 15* max.
Yea, the 9's are really sensitive to max timing. 15 is actually alot more than what I am used to on 9's since you are on 93 I believe. I usually tune the 91 octane 9's to about 10-13* max. Depending on mods of course.
93 PON IX timing, max knock count up to 3 (usually 0/1 occasionally 2 rarely 3).
I hope I'm not polluting your thread Bryan, but this is a great thread to discuss ignition timing styles/methods rather than being 8 or 9 specific.
Yea, that's way more timing up top than I can run on 9's on 91 octane here.
Some cars respond well to the way you have done your timing, some seem to not like it so much.
I see you got some skills..the transitions in the map are so smooth like a baby's bottom. Your fuel map looks just like mine just I have more high 9's than you to get me in the 11.0 to 11.5 afr
Remember this is on 100 octane. It's actually about what I am running at 3500 on 91 octane as well, but with almost 4 more psi.
Sure, just to get some fine tuning in some sensitive areas on my car. I used to have 5000 5250 5500 instead of 6500 6750 because on pump 5-5500 was sensitive. With my current mods it moved up a little.
2 questions for ya Bryan.
1. What color scheme is that? I've always tried to figure that out lol
2. With your injector scaling, your AFR is still about 1.5 higher than your map? Are you satisfied with that scaling?
1. Color scheme is Volcano
2. Scaling is pretty much spot on with fuel trims so it's correct. Fuel map numbers don't really matter to me as I only use the numbers for smoothing and not to calculate actual AFR off them.
Bryan -- Why are you (and a lot of folks in Cali.) running 720cc injectors? I believe that with my current tune, I am close to running out of injector and wonder if the bigger injector is needed for 91 oct. or if it just gives you a more precise injection? Thanks
I can run about 18 degrees uptop typically on the ix's on 92 we do...
curious...
cb
