349whp mustang dyno EcuFlash Map
Since my personal EVO has turned into a sort of testbed, I figured I would post up my current EcuFlash map that makes 349whp.
There are some maps I am not showing but the overall tune is here.
As usual, don't copy it and expect your car to run well, I'm not responsible for it's use on anything other than my own personal EVO.
There are some big changes here and some subtle changes that some might actually miss at first glance.
Am I crazy for posting this? Yea maybe, but hey what the hell. I'm all for sparking conversation.
Here is a sample log from that tune:
Here is a dyno chart from that tune, this mustang reads very low, much like Buschurs. For perspective, a well-driven 300whp evo on this dyno can run 11.9's.
Here are the mods:
GST ECU-based boost control at 25.5psi peak.
Vishnu cat-back
RRE Rally cat
Espelir 2.75" DP
K&N drop in (stock airbox)
Nisei LICP
HKS 272/272 cams
ARP head studs
MR BOV
HKS cam gears as +1/-1
Denso 720cc injectors
Walboro Fuel Pump
Stock 05 turbo, 02 housing, exhaust manifold (all unported)
100 octane unleaded VP racing fuel
11.5 AFR
Vishnu cat-back
RRE Rally cat
Espelir 2.75" DP
Nisei LICP
HKS 272/272 cams
ARP head studs
MR BOV
Walboro Fuel Pump
11.5 AFR
Interesting...regarding your injector battery voltage latency and injector scaling. Different strokes!
I also like the Y axis on the ignition map...koo!
Thanks Bryan, I enjoyed looking through your maps and I like them. Although our specs differ (my octane is about 95 [~93PON+10% meth in tank] and I have a IX on standard cams but quite similar otherwise), our styles appear similar in terms of sensible timing and smoothness which comes through in your posts, and the maps are broadly similar except you can run more timing up top. I run very similar to your duty cycle profile on my AVC-R.
Timing here: http://john824.fotopic.net/p38418308.html
I would say your maps are an example of good tuning and will be educational for users to compare with standard to see what you've done.
Of course there are more than one way to tune but for my personal car, this works the best so far.
I find it interesting that your timing near onset of boost is about what mine is on 93 with the better cooling passages and MIVEC. You ramp up the timing alot faster than I can without the aforementioned "grumpiness" though. My car on pump doesnt seem to like much more than 15* max.
