log boost with JDM MAP sensor (updated instructions)
#496
The lower the idle, the lower closer the pressure will be to zero. -8 to -9 psi is typical for 850 rpm. If your car is idling below that, the pressure could be less. Also, I think aftermarket cams can affect the pressure at idle
#497
My idle is high for some reason could be due to the bad maf wont know for sure till tuesday.
As for cams i have 272 hks I&E cams, hks suction reloaded intake, hks evc, hks tbe, all of this was bought with the car plus a boost gauge and old dyno flash tune. Not sure still what else is done to it. They said there was 10k invested by previous owner but who knows.
#500
What should be in the protocols. xml for Logworks? I'd like to check my work.
Looking at it, I'm set at 0 & 30 for the min and max by the look of it. Probably the problem. What should be the "min" ?
Or is this just wrong?
<datachannel id="#38" name="JDM Map Sensor" selected="1" units="PSI" min="0" max="30" expr="(x*0.19347)-14.2" type="0"/>
#502
Thanks boss. Will that change the scale in comparison to what I have been seeing? Like by starting at "0" have I skewed the output scale? Or is it just not showing me values below "0".
Just wondering.
Guess I'll go for a log and see. I haven't changed the boost since my last trip out logging.
Just wondering.
#507
