log boost with JDM MAP sensor (updated instructions)
#556
Any tephra 90550001 rom out there able to log 3bar map sensor? It work straight out by replacing the map and log with evoscan. Hope to hear more story.. cossie/burger?
#559
MrFred, you said there is an address that logs the MAP sensor input in 2 byte rather than 1 byte before when we were trying to get the zeitronix 3.5bar map sensor working. I wanna start gathering data for that but I would need to be able to log the raw 2 byte bits to start figuring it out. Any way I can find out what address that would be for my 94170015 rom?
#563
from what i have seen the jdm 3bar will only read up to 30ish psi. is there any hope for us guys running 32-35psi and be able to log boost? maybe figure out how to get the aem 5bar sensor to work? sorry if this has been talked about already....thanks
#566
Is there any programming that's required to make them work?
#569
Working on my heat pump system tonight. Outside temp is ~10F for the first time in maybe two years or more. The aux heat is blowing the breaker, and in looking at the air handler specs, it looks like the HVAC installer used an undersized breaker. Ah the world of professionals. Some really are professionals. Some are just masquerading.
#570
Boils down to being -16 outside, heater will only go up to 69* and quit. My son is 8 months old and thus cannot control body temperature. I and my wife had to wrap him in blankets and his Eskimo suit to keep him warm through the night.
Come to find out, the filter was clogged preventing air from keeping the sensor cool and not tripping it. The wife sent me to the garage to sleep in the Evo for an hour.
-E
