Pill Placement for ECU Boost Control
Check this post out from Works. I know it is from the vendor and vendors are suspect, but if their testing results is correct, then they have pretty good boost control.
https://www.evolutionm.net/forums/sh...63&postcount=6
Here is the full thread.
https://www.evolutionm.net/forums/sh...ht=Works+boost
I will test their system and see for myself.
This PM, I removed my Xede and installed my stock pill on the Solenoid side and the Works smaller orificed pill on the turbo side. I kept the boost tables stock. I want to log the car with this set-up first and check the boost curve.
What do you guys predict as far as boost taper? Would there be more taper from stock with the Works pill or less taper from stock from the Works pill?
Maybe a little less taper.
Curious about the results.
Using a 3 port boost solenoid, like this one..
http://www.perrinperformance.com/pro...22&category=37
With this you just run regular lines, with no pills. Also, this solenoid doesnt need resistors or anything. This is the best way to control boost using the ECU.
cml899
Apr 29, 2005 06:33 AM
