Tuning 1000cc injectors on ECU Flash
Old Apr 9, 2007, 02:01 PM
PDXEvo's Avatar
I think the only limitation of the stock ECU is your patience. Already the stock ECU has been shown to run a GT35r, which was previously thought to be impossible. I see you got your mid ft's down in the 90's. Let me know how your cruise stuff goes. That was the toughest part for me with the larger injectors.
Old Apr 9, 2007, 02:08 PM
Spooldyou's Avatar
Yup, thats the PITA part that i was refering too, I think im a pretty patient person, so we'll see how long it takes to make it all run right. Even though im sure i will always be changing my tune.
dudical26's Avatar
Originally Posted by bboypuertoroc
There's another thread on here relating to tuning for larger injectors using info from the AEM EMS... they talked about tuning 1000cc injectors in that thread. Can't remember how I found it though... I'll see if I can dig it up.
found it -
https://www.evolutionm.net/forums/sh...=207924&page=7
Old Apr 9, 2007, 02:27 PM
Spooldyou's Avatar
Originally Posted by dudical26
Wow, thats a great amount of very useful info!
gunzo's Avatar
If you go by Hexadecimal .. the theoretical limit of the injector sizing is 29000+
Anyway .. it's a reducing value .. ie the higher the injector you set .. the lower the value in the ROM .. so the lowest valid number you can go to is 0x0001
For 1000cc injectors to idle within +/- 5% of fuel trims, I have mine set to 913 (0x0020) and latency of 0.960ms@14.06v
Old Apr 9, 2007, 04:20 PM
A418t81's Avatar
My stock ECU runs my 35R setup exceptionally well. Some similarly setup evos with AEMs and tunes by the "uber tuners" weren't exactly happy when we hit it
Old Apr 9, 2007, 04:34 PM
BaLListic_EVO's Avatar
i had seen a stock bottom end evo on 280's tuned on 1000CC injectors and the car ran pretty decent but as figured had a horrible idle..... I believe the car made 550ish
Old Apr 9, 2007, 11:09 PM
BiFfMaN's Avatar
Originally Posted by ewoevo
I'm interested in tuning 1,00cc injectors on stock ECU. I'm wanting to convert to E85 and put in a set of 1,000cc's I have lying around.
yah i have the same thing planned myself..BUT with the new turbo going in i might need 1200's to reach the goal of 450hp on a 50 trim alone on E85.
Old Apr 10, 2007, 02:02 AM
vboy425's Avatar
i have tuned two evos with RC 1000CC. No issues at all.
Old May 2, 2007, 07:18 PM
denolloyd's Avatar
Old thread but see my sig. 1000cc injectors work just fine with the stock ecu
Old May 2, 2007, 07:30 PM
fastct9a's Avatar
Awesome man. Jester tuning great company. What psi was that at?
Old May 2, 2007, 07:33 PM
JohnBradley's Avatar
edit
Old May 2, 2007, 07:36 PM
denolloyd's Avatar
36...
Stock Intake Manifold
Stock Throttle Body
Stock Head
HKS 280's
Ebay Intercooler
Pleanty of room for improvement with this sized turbo...
Old May 2, 2007, 09:10 PM
ST
ST's Avatar
I think part of the confusion stems from the injector latency value only topping out at 7XX (or 8XX I forgot). People don't realize you can manually input higher figures thus claim it's limited. Personally I have tuned with 1000cc's w/ with ecu flash and had no issues.
Old May 2, 2007, 09:14 PM
Actually its not the latency value that tops out, you meant the scaling value I think. It just dawned on me in when I was disabling my rear O2 subroutine a few weeks ago (and again this morning on an different map) that it might be possible and sure enough it worked (well as far as inputing the number anyway). I havent had a chance to try it out on anyone yet though as I only have 750's.
p.s. its 770cc
Quick Reply: Tuning 1000cc injectors on ECU Flash
