96940011 05 EVOVIII ROM: Known Patches
Old Jul 20, 2009 | 05:45 PM
  #91
MR. EVO MR's Avatar
my bible
Old Aug 19, 2009 | 02:11 PM
  #92
WhiteEvo05's Avatar
Well two years later, and I am still the dumb kid in the class
I am noticing in the newest EcuFlash (1.42.2595), in the Evo7base_20081101.xml, the MUT table has a Y axis that reads MUT0X, MUT1X...MUT1DX, for a total of thirty elements. In the older versions of EcuFlash, the MUT table was defined as having 32 elements in the Y axis (though there are 33 data items...? See post #40 in this thread) and they are listed as 3f314 through 3f714.
Now I realize the naming of the elements as either MUT0X or 3f314 is a matter of semantics...you could call them "Eugene1", "Eugene2", etc. if you wanted. What I am wondering is whether the 32 (or 33?) lines is correct, or is the 30 lines as defined in v1.42 correct?
The same question is true for the X axis...old was 16 elements (again see code in post #40), the newest has 32...which is correct?
Any of you smart kids want to clear this up for the "back rowers"?
Old Aug 21, 2009 | 07:48 PM
  #93
shadow1's Avatar
Anyone know the lean spool load thresholds and trailing times for 96940011?
Old Oct 5, 2010 | 03:08 PM
  #94
deeman101's Avatar
Does anybody know the address for the decel fuel cut delay?
Old Nov 8, 2010 | 01:51 AM
  #95
Evo-B's Avatar
So I have been searching for a while now and cannot find the Lean Spool tables for this Rom. Just wondering if any body has these tables. I am starting to tune and I would rather work with the system not against it.
Old Nov 17, 2010 | 01:54 PM
  #96
deeman101's Avatar
I'm not totally sure but doesn't ECU flash already display the lean spool tables (on v1.42 at least)? Are those addresses inaccurate?
Old Nov 17, 2010 | 02:12 PM
  #97
shadow1's Avatar
Most of the lean spool tables for 96940011 are defined. However I don't find them helpful since I turn off lean spool.
richardjh
Aug 24, 2022 11:50 PM
mrfred
May 1, 2020 11:16 AM
kalendrinn
Dec 14, 2015 11:40 PM
chaotichoax
Sep 7, 2015 08:41 PM
l2r99gst
Sep 19, 2012 09:03 AM
Quick Reply: 96940011 05 EVOVIII ROM: Known Patches
