Want to remove/disable your rear O2 sensor without a CEL? Here's how..
#155
just wanted to say that this worked like a charm. No more cel and I used a 50 ohm 10 watts resistor.......fireproof by the way due to the high temperatures....it's overkill but I know my carpets are safe.
#156
*nod* That's my problem right now: I have this ghetto-rigged under the passenger seat for testing, and it's definitely been working fine for several months, but the exposed resistor is not my preference.
Hmm. I wonder if running the original heater circuit to the heater on my wideband (which just physically replaced the old one anyway) would provide enough draw and resistance to fulfill the ECU's needs?
At the end of the day, I'd much rather solve this in code (there's no reason we shouldn't be able to simply disable the check, rather than physically simulating a heater circuit), but I've had no time to investigate it at all. Too many projects.
#157
#158
Yes it will pass the OBDII emissions check, not a "sniffer in your exhaust pipe" emissions test though if your smogging up the place. There is also the physical inspection and if the guy is smart and wants to be an ***...can tell you to remove the extension and re-take the test (unlikely at most shops though).
#159
Generally, no you can't do this. Or better yet, its not as wise to do this. Search for it on this forum or others, its been discussed enough to find out the exact reasons why.
#160
This rear O2 CEL fix is a standalone fix independent of the ROM changes described in first post. The resistor mod can still be applied to allow removing the rear O2 sensor from the car. I don't know if it will work with an 88590013 ROM. Try adding the definitions to the 88590013.xml file, and if the "stock" values you see match what I list, then it will work. I recommend switching to the 88590015 ROM though. I don't plan on porting any of my work to the 88590014 or the 88590013 ROMs. Its easier for all the people working on disassembly to focus on only a few key ROMs.
#161
It make sense for everyone to adopt 8859015.xml, probably a HOW TO could help a bunch of people with the EVO 9.
#163
Sorry, but it wont work on an Evo 8. A different patch will be needed for each ROM. tephra is incorporating it into his v5 ROM, so if you can hang tight for a little while, that will be the easiest way to get the patch.
#164
Great! Please can you be so kind to tell how to change my 13 ROM to 15? I noticed most "fix" come out first for the 88590015 ROM........I tried search but I can't find anthying.
