Want to remove/disable your rear O2 sensor without a CEL? Here's how..
Old Oct 21, 2007, 10:44 PM
  #91
raiceboi697's Avatar
well it works as i did it on mine but now im throwing the o2 sensor voltage high, sensor 1 bank 1, is this the o2 in the O2 housing? if so does anyone have ideas
Old Oct 22, 2007, 10:22 PM
  #92
tephra's Avatar
whats the code?
Old Oct 23, 2007, 12:31 PM
  #93
p0132 i think ill have to check in a bit
Old Oct 24, 2007, 05:47 AM
  #94
honki24's Avatar
Originally Posted by SuPeRNeT
If you have a xede /w smart, the knock box has a front o2 sim built in so no need to do any of this for the 8 just wire in the o2 harness to the box and your set!!
for all the xede haters
ECU+ will simulate both the front and rear 02 sensors. (front for if you want closed loop to be at a different AFR for something like better fuel economy)
Old Oct 25, 2007, 04:02 AM
  #95
tephra's Avatar
well I found the P0125 thing - and now I'm throwing P0134 - in fact I can throw whatever code I like - lol!
next i am going to reverse engineer how the code is thrown... see if I can accidentally come across a flag or something
Old Oct 27, 2007, 07:52 AM
  #96
there you go again making the evoflash world better!!
Old Nov 23, 2007, 12:38 AM
  #97
KOOLER's Avatar
I have a bit different but very close problem. Car also goes very slow and has bad idle. From the loggers I see front O2 sensor shows morbid values. Around 4.5 V instead of 0..1 V. However physically attached tester shows correct values 0..1 V so it makes me assume it's ECU "thinks" or somehow interprets the correct signal as 4.5 V. Also car CELs P0125 all the time... I have default values for:
ECU Periphery0 = 0x56DA
and also default value for:
Min temp for closed loop = 0
Can anybody suggest me what to do?
Thank you!
Anton
Old Nov 26, 2007, 09:41 AM
  #98
krazykorean84's Avatar
I can't wait to do this mod so I can run my wideband in the test pipe bung.
Just on quick question.... can disconnecting the downstream O2 sensor by doing this mod affect gas mileage at all?
Old Nov 28, 2007, 03:13 AM
  #99
dark-evo's Avatar
Thank you!
Anton
check your 02 wires
and will be happy
Old Nov 28, 2007, 09:25 AM
  #100
Mojo Rising's Avatar
No. The only reason for the rear O2 sensor in vehicles is to do a Catalyst check. Basically it makes sure your Cat is working properly. This is mandated by law, or else we would only have a front O2.
Old Nov 28, 2007, 10:28 AM
  #101
crisdawg's Avatar
be aware that if you do this mod and remove your oem rear o2 sensor and put the wideband in you wont complete the o2 sensor heater readiness test. which in return will cause you to fail emissions in most states. if im wrong someone please correct me but im pretty sure this is true.
Old Nov 28, 2007, 04:25 PM
  #102
This is true.
Old Dec 2, 2007, 09:12 AM
  #103
Excellent. Thanks for the answer. I won't need to worry about emissions anytime soon since aren't any emissions tests in most of the southern states. Thanks again.
Old Dec 27, 2007, 06:41 AM
  #104
al\lupo's Avatar
Did you find something interesting in reverse?
Old Dec 28, 2007, 01:16 AM
  #105
al\lupo's Avatar
It's funny that with P0125 the car seems to warm up very very slowly... same street, same hour and twice the time to warm up.
On the flash side, I can see that the bitmap to change (0x56DA @ 0xFAA address) is repeated 8 times and the last one is different. I tried to zero the O2 bit on all but P0125 is still thrown...
Quick Reply: Want to remove/disable your rear O2 sensor without a CEL? Here's how..
