Evo anti-lag ECU disassembly
#618
Unfortunately, we still missing the proper code to operate proper anti lag. With the current decoded SAS tables you get pops & bangs only, no positive boost!
Try rom id 9055
Try rom id 9055
#619
It's been a while and I'm joining late, but I just got done reading through the entire thread. I've got some SAS hardware en route from the UK, I was hoping someone had figured out how to implement the code and execute it, but it appears efforts where in vane. Silex, where you ever able to secure the SAS unit? Btw, I'm hoping to implement this in -15 ROM running Tephra V7. As many, I've only gotten to the point of pops and bangs. No overrun. If only there where some way of disabling overrun fuel cut....
I'd love to help in any way I can to move this project forward, but unfortunately I'm just a tuner, and have no knowledge of diss, so I'm pretty much just in here to check up on things and see if anyone got it working.
#621
Tunermt says he made boost in the manifold with a home brewed pipeline and aem. I know, the only way you can get boost in the manifold is by letting it in. A normal iscv cannot do this as i have tested with a vipec using the iscv as the air bypass for als and it doesn't move enough air. --The leak from a sas system might be just enough to build some however the purpose of this again is drivable ( with brake booster ).
mrfred
Sep 14, 2022 07:08 PM
Richard L
149
Feb 27, 2016 03:01 PM
