? about Vishnu ECU Flash
If anyone has had it done how do you like it and is it worth getting done. What is the gas mileage difference and has anyone had it flash just on what they had done to the car. And did it make a difference than just getting the flash then buying the parts?? Thanks
I would say pick someone else.. unless you like knock and to much timing...I know 2 other evo owners here including myself that had a vishnu flash and have that problem..myself 5-9 counts +4 deg to much timing in 2 spots. Another guy 4-5 counts from 5000rpm to redline. So yeah not to thrilled with it. Now with a Doug Dyno flash I have 0 counts at 22 psi on 91 pump ****.
A dyno tune from Vishnu might be a good thing, but their mail-in flash definitely has some pitfalls (and some nice things). The mail-in flash that I received was conservative on timing, but not on fuel. The boost management system was not terribly consistent either. I was frequently seeing knock sums of 7-10 at high rpm (high enough for the ECU pull back several degrees of timing), and was also seeing occasional knock sums of 15-20 at mid-rpm values (well beyond acceptable). I was also getting boost overshoot (which was contributing to the knock). I ended up using his flash as a base for my tuning.
The good thing I've noticed about the mail-in Vishnu flash is that Shiv does tinker with the maps to improve daily driveablility. The car has much better driveability in the 2-3k rpm range with his tune, and after getting fuel and boost under control, I'm quite happy with things.
Overall though, it was a nightmare with the high knock counts and 25+ psi boost overshoot from a $750 product. I wouldn't recommend it to anyone. And since Shiv is still charging $750, I think Shiv is still tuning with ECUtek which likely has access to only a subset of the maps that are now available with ECUFlash. (Either that or he has switched over to ECUFlash and is raking in a huge profit on each mail-in flash.)
EDIT: And don't believe the advertised 100-130 hp gains. The best anyone can expect from a reliable flash on a stock car with pump gas is about 50 whp which would be about 65-70 bhp at the most.
If you are looking to get tuned and not be adventurous yourself, I know that Doug at TopSpeed is a great tuner. But you'll need to visit Atlanta for a tune from him. I've heard good things about Mellon as well, but have not seen his tunes myself.
Good luck!
I have to strongly disagree here. The IX flashes that I have seen from Vishnu are very safe and fruitful purchases. The base Evo IX map should not knock on a stock car. The most important thing is to make sure that you specify your location and octane requirements.
If you're thinking about buying parts, you map will almost certainly need to be changed after you install them.
d
EDIT: This discussion has happened many times, but I feel it is important to remind folks that 'knockcount' is just a measure of noise and no certain value indicates that the engine is actually knocking. Even a good tune (or stock) will experience knock count readings in weather significantly different that when the map was made. Again this is not meant to sway the argument either way.
d
The IX map with the MIVEC that shows advance greater than the system can actually do? His actual tuning ability or salemanship aside, anyone that sells a product without knowing what the overall parameters are of said adjustments has earned no rights to work on anyone cars...even if it doesnt knock.
ESPECIALLY when he charges 5 times the going rate.
ya vishnu sucks, a tune magazine hired them to do there evo and it went in limp mode thanks to the sucky vishnu tune they did on it. I have also heard from countless people about there way to aggresive high knock tune.
d
d
With my current tune, the most knock I ever see is about 3 counts. And I have switched back and forth between my tune and the original Vishnu mail-in tune (with the exception of better boost control) and watched the knock counts return at high rpm. So this isn't some phantom knock thing.
Maybe maybe a Vishnu mail-in works good on some cars, but it definitely doesn't work good on all cars.
I wasn't meaning to take a side, that just hasn't been my experience. I think most of us sensible people would agree that knock counts as high as 20-30 should _not_ be the target.
Getting into specific number arguments is useless because I'm at much higher altitude than most readers. 26 psi on my boost gauge is not the same as it would be on yours.
Either way, there's no point in debating. You had a bad experience. I had a good one. We should get back to hacking the stock ECU.
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
d
its good to get detail on what others have experienced, its not a waste of time at all to discuss things like this. Sometimes like girls, its good to gossip to, jus to shoot sh$% when your bored.
Either way, there's no point in debating. You had a bad experience. I had a good one. We should get back to hacking the stock ECU.![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
d
d
In addition, disassembly of the ECU code shows there are several other variables that effect the ECUs handling of the input from the knock filter. You might find some more information at Aktive Matrix. If you look around the net you can also see different strategies for handling raw knock data.
MB
05blue8
11
Apr 19, 2007 06:28 PM
