Odd knock sum/jolt episode
I think I know why my car doesn't like any midrange timing -- my somewhat restrictive muffler. I'm currently running a 3" O2 (WORKS), with the WORKS 3" DP, test pipe, WORKS 3" IP, mated up to a StealthWORKS muffler, which is a modified stock muffler. The flange on the stock muffler only has a 2.5" or so opening, so there's a significant flow disruption occurring. During WOT runs, the restriction is there....but when I let off of the throttle, that backpressure sends a shockwave all the way to the engine. By running very little mid-load timing, I'm able to avoid knock. I'll attach of log of what happens when I run a reasonable mid-load timing map.
What do you think of this theory? It makes sense to me, and I know the car didn't do this when I was running my 3" TBE.
My problem was instantly cured with a 3" muffler. It was the stock muffler inlet flange and modified stock muffler (StealthWORKS) that was causing the problem. I'm back to running healthy midrange timing again.
John you have a stock job? I guess you don't really need to change much if you have a FQXXX.
I don't remember my car ever doing this. I have a turbo-back and a Tomei BOV so I'm on a different boat I guess.
But I'll try to keep an eye out.
We (UK) would refer to the standard unit as a recirculating dump valve or a recirculating blow off valve (as opposed to vent to atmosphere). Whatever your preferred terminology, I have the standard arrangement which we're all familiar with
It is funny I found this thread because I have been having a similar problem recently, but in the opposite effect. When cruising, lean into the throttle alittle and back out half way and it goes real rich (10:1) then jumps alittle lean (15.8:1) and then it settles back to 14.7:1, no knock. Mostly only happens in higher gears too. But I can make it happen on command. I have PTE 780cc injectors and so far I have tried: rescaling injectors, raising/lowering latencies, went back to stockairbox with nothing helping. Also sometimes the car freaks out and goes real lean when coming to a rolling stop with the clutch in but eventually settles back to stoich. Please keep the thread updated if you guys come across any more info .
Live4Redline
Jul 17, 2024 07:09 AM
Richy2703
Mar 4, 2020 10:11 AM
D1andonlyantman
21
Apr 2, 2016 12:31 PM
Rokpapaziz
15
Jul 1, 2012 11:39 AM
