ecuflash failed in the midle of a flash
need help or opinions, i did my first flash a week ago and everething is going ok. yestarday i did a new flash and in the midle it failaied, it said to start again and that it was going to recallit from the place it was lost but the same thing hapend, and the next atempt it is not conecting any more.
the mesage is:[12:03:18.110] Using interface OpenPort 1.3 Mitsubishi TX35rBOSfe1ab7c956c5f0aae78b9598f7276a5dc3826586
[12:05:08.489] sending init sequence 1 (0001)
[12:05:11.753] sending init sequence 1 (0003)
[12:05:15.028] sending init sequence 1 (FFFF)
[12:05:17.792] no response to any known code
i have to say that the car runs fine and i have get these mesage before sometimes and it just does not conect and the next day it does
what should i do
thanks in advance
what should i do
thanks in advance
Try another computer. Seems like a connection problem or a software problem. I get errors when my usb cable is not plugged in the same port that it is set up for.
at first i tried to use the unloker but i have some wierd problem since its not the first time it is not conecting and yesterday i did a back up and the initial code still 0001
And about the failed flash have any body have isues with a mid flash
I have tried a lot of things, is there anybody with a 1.28 version of the ecuflash so the unloker works poperly.
I have chek and rechek the cables and i cant find any isues
