How much hp with good timing?
I don't know about evo 9's but I picked up more power by adding timing than boost. If I tune to the edge at 20 psi and about 14 degrees of timing up top the car is noticably faster than if I tune for say, 23 psi and 9 degrees of timing up top, which seem to be the timing numbers that my motor starts seeing knock at. I would rather be able to tell people im on 20 pounds than 23 as well.
I believe you, but could you give me data to back this up?
As I mentioned, getting to that magic 15º ATDC point is the key. Once you are there, boost will always make power assuming you keep away from knock. That's where the turbo's efficiency range and fuel octane comes in.
