how-to: ECU-based direct boost control
Old Mar 6, 2008 | 11:53 AM
  #271
MR Turco's Avatar
Originally Posted by razorlab
You posted the same image?
Check again, i just updated the pic on the server.
Old Mar 6, 2008 | 11:58 AM
  #272
MR Turco's Avatar
Might be a tad too much duty cycle up top if your target is 16psi.
I would run 50-60 from 5430 up for the first couple datalogs and see what that gets you, then add from there.
Awesome thanks. I agree, now that i am looking at again.
Old Mar 7, 2008 | 06:11 AM
  #273
DCsleeper's Avatar
Does anyone know for sure whether or not this patch works with ROM 94170015? This is the last rom for 03/04 VIII models in the 9417XXXX family.
I upgraded to 94170015 to minimize the p0300 error that I get from time to time.
Old Mar 8, 2008 | 06:44 AM
  #274
MR Turco's Avatar
Well i did get this setup and all i have to say is WOW. This is incredibly easy to tune and works PERFECT. Mrfred, thank you.
I would like to make one request. I am not sure of how difficult this would be so i dont mean to if what i ask is some incredibly large request.
Would it be possible to make the desired boost a 3D table where we could factor in TPS so that full boost doesnt come on part throttle? We should only need 4 columns for TPS settings and let the computer interpolate. My roommate, the one helping me learn how to tune my car, has this for his suby and it seems to make DD a lot more friendly.
Old Mar 8, 2008 | 07:14 PM
  #275
mrfred's Avatar
tephra and I have been talking about writing a full PID controller to replace the stock boost control setup. We did touch on the part throttle boost control issue. If he hasn't already seen your post, I'll mention it to him as he's doing the coding because I haven't been able to find the time for something like this.
Old Mar 8, 2008 | 07:23 PM
  #276
tephra's Avatar
yeah easy done - lol
I'm going away for a week, so when I get back I will be testing my boost controller.. hopefully "it just works "
Old Mar 9, 2008 | 08:18 AM
  #277
DCsleeper's Avatar
Anybody?
Old Mar 9, 2008 | 10:09 AM
  #278
MR Turco's Avatar
Mrfred, that sounds great! Your system works very well and I have no problems using it as it. I guess it is more of a second revision request if a second revision ever comes out.
Tephra, does that mean you have it done? If so do you have a 3D table for Target Boost and BWGDC?
Old Mar 9, 2008 | 03:28 PM
  #279
MR Turco's Avatar
Just out of curiosity, if you have WGDC at 100% and you are lower than target boost, will the computer add correction since it is maxed out?
Old Mar 9, 2008 | 03:33 PM
  #280
RazorLab's Avatar
Yes, but you won't get any more boost after 100%
Old Mar 9, 2008 | 03:35 PM
  #281
MR Turco's Avatar
Yeah I know I am just wondering if it will even try to add if the cell is already maxed out.
Old Mar 9, 2008 | 03:45 PM
  #282
mrfred's Avatar
No. There is code that clips all requests for more than 100% WGDC.
Old Mar 17, 2008 | 03:38 PM
  #283
MR Turco's Avatar
Mrfred, is there some sort of TPS threshold that is accounted for before the correction tries to take over? For instance, if i have 2% at -3.1 boost correction if i am not getting on the car it will not try to correct. Is there something built in that will stop the correction until a certain load or tps value?
Old Mar 17, 2008 | 04:01 PM
  #284
RazorLab's Avatar
There is a "Max WGDC Correction vs TPS" table.
Old Mar 17, 2008 | 06:08 PM
  #285
MR Turco's Avatar
?? i dont have said table. I am running 1.29a, is it in a newer version of ecuflash?
Quick Reply: how-to: ECU-based direct boost control
