how-to: ECU-based direct boost control
Old Oct 3, 2008 | 08:36 AM
  #436
borjaland's Avatar
Thank you very much MrFred !!!! My ecuflash version is 1.35, I´ve changed the values little to big and now the maps shows good values!!!!!
Boost Adder 9.3 psia
Boost Error Correction
on boost error psi cels:
-3.0888
-2.7027
-2.3166
-1.9305
-1.5444
-1.1583
-0.772201
-0.3861
0.772201
1.1583
1.5444
1.9305
2.3166
2.7027
3.06467
wgdc cels:
4.5
3.5
-3.5
-5
-6.5
-13
-13
-13
-13
Old Oct 3, 2008 | 08:47 AM
  #437
mrfred's Avatar
Originally Posted by borjaland
Hi to every body from spain!!
I´m trying to make the modifiation in a 96420008 rom, but the Boost Error correction and the Boost Adder maps , shows the psi values differents from the other roms on this thread.
On the next picture you can see all new boost control maps.
Can be an address problem???
I found a "96420008" ROM that gives the exact same values that you posted. I looked at the disassem, and its not really a 96420008 ROM. Someone changed the internal ID. Your ROM must also have a changed ID. I bet its a 9641XXXX ROM.
Old Oct 3, 2008 | 09:05 AM
  #438
borjaland's Avatar
could be, I´ve imported the car from USA to spain, the car had some modifications.
How do you see the new values after change the endian values from "little" to "big" ??????
Thanks MrFred!!!!!!!!
Old Oct 3, 2008 | 09:20 AM
  #439
mrfred's Avatar
-3.0888
-2.7027
-2.3166
-1.9305
-1.5444
-1.1583
-0.772201
-0.3861
0.772201
1.1583
1.5444
1.9305
2.3166
2.7027
3.06467
wgdc cels:
4.5
3.5
-3.5
-5
-6.5
-13
-13
-13
-13
If the "little" to "big" works for you, then please disregard my previous post. Your ROM is a 96420008.
Old Oct 3, 2008 | 09:35 AM
  #440
borjaland's Avatar
Ok Thanks
Old Oct 7, 2008 | 04:33 PM
  #441
lan_evo_mr9's Avatar
Is there any way to go higher than 24.6 actual psi for e85 use?
Old Oct 7, 2008 | 04:55 PM
  #442
mrfred's Avatar
Sure, just set the boost adder to say 24.5 psi. The max possible boost will then be 34.6 psi.
  #443
RazorLab's Avatar
Yes, just up the Boost Adder and do the math
Example:
Boost adder = 20
Baseline Boost table @ 4000 = 23
20+23= 43
Minus your atmospheric, let's say 14.7
43-14.7 = 28.3 psi
Old Oct 8, 2008 | 07:24 PM
  #444
dan l's Avatar
However if your on the 3 bar map you really can't control anything over 29psi.
Old Oct 8, 2008 | 07:46 PM
  #445
Where do I patch the new rom mod to? boost section of stock rom or at the end of the stock rom like tephra mods or anywhere else?
Old Oct 8, 2008 | 07:51 PM
  #446
can the stock solenoid handle that or do I have to get the 3 port?
Old Oct 8, 2008 | 08:00 PM
  #447
RazorLab's Avatar
I've run up to 32-33psi logged with the 3 bar. I'll try to find the logs...
Old Oct 8, 2008 | 08:14 PM
  #448
RazorLab's Avatar
Here are a couple log data points from two different evos:
RPM - 3719
Load - 329.38
Boost - 30.57
RPM - 4250
Load - 330.30
Boost - 31.35
RPM - 4219
Load - 328.12
Boost - 31.93
Old Oct 8, 2008 | 08:21 PM
  #449
mrfred's Avatar
mixmastermatt has also logged up to 32 psi.
Old Oct 8, 2008 | 09:13 PM
  #450
house_of_senate's Avatar
So do you guys think I would see any improvement after switching to this? I use an AEM solenoid to control boost by LOAD right now. It always seems consistent...
Quick Reply: how-to: ECU-based direct boost control
