how-to: ECU-based direct boost control
#466
I am interested to see what other patches you have up your sleeve.
#467
I wouldn't say House is a "hugs all around" kind of guy,lol. I still can't believe he's European and has a STRONG accent. He can play an American VERY well....especially the arrogance lol. I'm a House man as well
I'm in no rush for theT2 map sensor patch, the season is prettyy much over for me now. Like the old saying goes "Take your time...but hurry up"
#468
^^ haha obviously i meant it in the house sort of way.
Anyway, i know tephra is working on some tables for a more PID like boost control system. I am not sure how far out that is but could a TPS x BWGDC be implimented? We would only need 3-4 columns for TPS. 25%, 50% 75% 100% just to help with part throttle boost.
#469
House rocks.
I have been a bit slack about the boost control stuff. I have done the PID code, but obviously tuning PID is an art in it self.
One day (hopefully soon) I will revisit it.
I have a trackday tomorrow at Phillip Island (we just had the Superbike World Champ round there) so I have been getting ready for that
#472
#474
I've never looked at that ROM. Not sure when I'll have a chance. In the mean time, you can add the tables to the xml and have a look at what values they show in ECUFlash. In my how-to, I list the stock value for each setting that needs to be modified. If all the values in the 96420011 match what I list, then it should work.
#475
#477
I have a basic question perhaps, but I haven't found the answer in different threads yet,
I am still having boost taper at 7500-7800 rpm. I have turned 2 full turns my FP18psi WGA. That for sure increased boost across the range, did not seem to do much for the taper.
Should I: A) Increase preload some more. B) Use a pill in the WGA line. or C)?
Using load based control via Mac Valve until my map sensor is here. The WGDC follows almost exactly what I have set for alternate base wastegate duty, until 7500ish or so rpm at which point WGDC maxes (100%) and I still have taper. Any thoughts are much appreciated.
Side question: How am I able to get WGDC to show inside DLL? anyone have a complete xml file for that program? Thanks!
#479
So, more preload isnt going to help im guessing?
#480
1) Ditch the stock airbox for a good cone filter setup. razorlab has found it makes a substantial improvement in high rpm power when going from the stock airbox to his GST cone filter.
2) Install an aftermarket O2 housing. I prefer the Titek as its very well made and there will be no boost creep issues with it.
