how-to: ECU-based direct boost control
Old Nov 17, 2008 | 07:46 PM
  #541
sharkm87's Avatar
i think i found the issue the left side of the BEC and TBEC aren't matched up...i know the tbec is -20 to 20 and the bec is -3 to 3..but thats not what i'm seeing...and i checked the xml and its exactly whats listed so i'm not sure whats being mis calculated.
Old Nov 17, 2008 | 08:57 PM
  #542
sharkm87's Avatar
for some reason with this boosterrorpsi formula...my -3.1 is -20 or 3.1 is 20 when convertin to TBEC, however all the middle numbers are skewed...
Old Nov 18, 2008 | 01:10 PM
  #543
mrfred's Avatar
Originally Posted by nonschlont
Ok, so I spent a few hours this weekend on a new rom w/ "direct boost control" dialing in 3rd gear (to start). and have come up w/ a couple more qustions...
1. I noticed on other peoples maps that have been posted, the WGDC is substanstially lower than w/ the stock BCS... But both the roms I have been working on (load/psi based) have had much higher WGDC. Well I decided I was gonna start from scratch and work my way up to desired boost levels... I basically set up the WGDC @ 100% @ 1000-2500, 75% @ 2750 and straight 50% till 6000, I left the rest of the map alone. Well this net me 14psi until 6000... So I started working my way up... Ended up w/ 100% till 2500, 85% @ 2750, and 80% till 4500, then tapering a bit. Im hitting desired boost perfectly. w/in -.5 to -.009, but hitting boost way late!!! 3750 +...
so my first question is why do I need to run soo much WGDC to achieve the similar boost levels that most are seeing w/ lower WGDC?
2. So I have my psi based rom set up for (3rd) on point, and Im hitting full boost @ 3750 +??? WTF??? w/ my load based rom, Im hitting same boost level @ 3406...
On another note this patch makes tuning boost much easier, I just wish I could figure out why Im hitting full boost so late...
1. Its possible that your WGA needs adjusting.
2. There's no reason why boost should be hitting so late compared to load-based boost control. Something is not right.
Originally Posted by sharkm87
i cannot get bec and wgdc change to log.they both stay at 0 for wgdc change and -3.081 for boost error correction.
so i dont think its changing anything...my wgdc looks spot on with my wgdc map....i can't figure it out
Post your BEC table.
Old Nov 18, 2008 | 02:37 PM
  #544
mplspilot's Avatar
try 100 duty through 3000 if you're using a 3 port.
Old Nov 18, 2008 | 02:42 PM
  #545
nonschlont's Avatar
[QUOTE=mrfred;6364560]1. Its possible that your WGA needs adjusting.
Can I send you my rom to look at? I believe all necessary changes were made, but, maybe... I missed somethin.
Theres really only 2 differences in my 2 roms (load/psi) Load I have WGDC set to a flat 77% till peak @ 80%, then tapering upward.
w/ PSI I had WGDC @ 100% till 2500 tapering down to 80% @ peak, thinking this would help spool up... looks like I thought wrong. lol
I would post up the logs, but Im having issues w/ zip files...
Old Nov 19, 2008 | 08:13 PM
  #546
nonschlont's Avatar
I thought about that... But wont that cause me to over shoot, in higher gears? Im not trying to argue, Im just trying to understand... I know u know ur stuff.
Old Dec 1, 2008 | 09:42 AM
  #547
GTLocke13's Avatar
Originally Posted by tephra
I have been a bit slack about the boost control stuff. I have done the PID code, but obviously tuning PID is an art in it self.
I don't know how feasible this is, but if you could output the P, I, and D values for the controller to Evoscan it would help make tuning easier.
The other thing that would make things easier is the ability to introduce a step change in the boost target. Map switching could do this, but you'd have to be on a dyno.
Old Dec 1, 2008 | 02:37 PM
  #548
tephra's Avatar
i am actually going to dump the PID idea. Now that we have gear based WGDC tuning boost is much easier... well not easier but we get more consistant results
Old Dec 1, 2008 | 04:14 PM
  #549
MR Turco's Avatar
I still think we need tables similar to evoX - mrfred said he already had them so if we can somehow incorporate them i am happy with what we have available.
Old Dec 1, 2008 | 04:24 PM
  #550
tephra's Avatar
well we can't have a 4d table - unfortunately.
so you can either have rpm vs throttle OR rpm vs gear.
Old Dec 1, 2008 | 04:28 PM
  #551
MR Turco's Avatar
what if we had a table that had TPS, RPM and % where % is the percentage of the WGDC value in the gear table. For instance if at 50% throttle i only wanted 50% of the WGDC value at that RPM in gear table. I personally think we would only need 4 colums for TPS, RPM range then %. I hope i am not asking for the world I just think ramp rate still needs to be address. I am very appreciative of the gear dependent boost, dont get me wrong.
Old Dec 1, 2008 | 04:39 PM
  #552
tephra's Avatar
mmm problem with that method is that wgdc doesn't linearly equal boost.
ie 50% wgdc might equal 20psi, but 25% wgdc doesn't equal 10psi.
I guess we can try it and see...
Old Dec 1, 2008 | 04:44 PM
  #553
MR Turco's Avatar
Oh yeah i understand that. I guess the point would just to really make part throttle spool more subtle. i am willing to deal with part throttle for the gear dependent boost so whatever can be done i am willing to accept - like i have a choice :P. I appreciate you at least entertaining the idea.
Old Dec 1, 2008 | 07:22 PM
  #554
Dapper Dan's Avatar
Has anyone had any problems with boost spiking at high rpms? I have my boost curve really good right now, but at 8000 rpms my boost just goes up past 35 psi. My target boost is 26 psi. Any ideas? I rescaled my rpm axis to 9000
Old Dec 1, 2008 | 07:26 PM
  #555
RazorLab's Avatar
yes the solenoid control turns off at 7500 rpm. You need to extend it past where you rev to.
it's the "Wastgate Solenoid Activation RPM" table
Quick Reply: how-to: ECU-based direct boost control
